Thread: CH Level UP ?
    Patrick's Avatar
    May 2009
    Central NJ
    29
    CH Level UP ?
    Since my conversion, I've been holding a CH level of 250 for the last few weeks. I have not added any calcium since the initial dose.
    Did my weekly test today (using TF-100). Tested the CH level again two hours later and still the exact same result. The pool looks great.
    FC- 7
    CC- 0
    PH- 7.7
    TA- 120
    CH- 360 (both times)
    CYA- 50
    I'm worried that if it continues to rise that I will begin to have problems.
    Any advice?
    Patrick - Central NJ (15th Season)
    19 K Gal. Free Form Gunite/White Plaster Finish
    Nautilius DE Filter (48 sq. ft. grid)
    Whisper 1 1/2 HP Pump
    Pentair MiniMax CH 250M Natural Gas Heater
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: CH Level UP ?
    As long as you keep your PH 7.6 or less you won't have a problem. Is your fill water high in CH?
    Patrick's Avatar
    May 2009
    Central NJ
    29
    Re: CH Level UP ?
    I lowered the PH a bit. I don't know what the CH level is on my fill water,
    but I haven't had to add any in the last couple weeks because of all the rain that we had.
    30,419
    Re: CH Level UP ?
    Patrick,
    There are really only two ways for CH to increase:
    1. Your fill water is very high in CH and is causing the increase
    2. You are adding it.
    Obviously you are not adding it on purpose. Are you using Cal Hypo to chlorinate? If not, I suspect a testing error....either on the current tests or, more likely, on the older ones.
    BTW, your water is spectacular!
    Guest
    Re: CH Level UP ?
    Remember that you can compensate for high CH by lowering the TA!
    Patrick's Avatar
    May 2009
    Central NJ
    29
    Re: CH Level UP ?
    I have been using just Clorox Bleach to chlorinate.
    I will try to lower the TA a bit.
