Thread: POLARIS 280 HELP!
    POLARIS 280 HELP!
    Moved to own thread by TFP moderator
    Waterbear
    HELP --- My Polarius 280 has stopped picking up anything. It appears as trhough the vacuum jets are not working at all. How does one clear the blockage and/or ensure the jets again are spraying? THANKS!!!
    3
    Re: POLARIS 280 HELP!
    Ok. The 280 is a simple cleaner as far as the drive components are concerned. If there is no or little pressure coming from the jets that suck debris up than you will need to look at a couple things.
    -First thing is that you can take a paper clip and bend it to poke into those jet holes. This will remove any lodged debri and may take a couple times because there may be more debri in the line.
    -There is a single screw that holds the top housing on the cleaner. If you take this off you can clean the jet inside the cleaner that actually drives it around the pool!
    Remember, there is always a source problem when things like this arise. In this case, it would be debris bypassing your main pool filter. Keep an eye on that little screen that is in the wall connection for your cleaner. If it is dirty go ahead and clean it if there is debris in there. Make sure the little screen is in good condition and has no broken screen. Lastly, watch that screen for a week or so and see how often it gets dirty. If it is getting dirty very quickly than your sorce issue is with your main pool filter letting dirt or debris back into the pool.
    -DrH2O
    25,000 gallon IG, vinyl, sand filter, with 1 HP pump
    Aug 2007
    near the swamp
    806
    As the Dr has described, take the 2 screws out of the bottom, remove the cover. Then remove the 2 screws that hold the 2 jets in place. Try not to lose the o-ring in the process. Then take a paper clip or something similar poke the holes to dislodge any debris that may be caught in them.
    Also you can remove the top cover and take the 3 screws that hold down the turbine cover, then look up inside it at the little hole. This little hole is what the water comes out of under pressure that drives the wheels. Sometimes it becomes clogged up by debris.
