Thread: Sliding board lines and fittings
    May 2009
    NC
    95
    I have an older sliding board that needs new lines and fittings. I initally went to Lowes and bought some clear tubbing. When I was removing the old stuff the fittings started falling apart from old age and deterioration. Does anyone know where I can get fittings? In will need one that attachs to the water hose at the base of the slide, then the water runs uphill to a fitting that dumps water at the top of the slide, then the water line runs back down to a fitting that dumps the rest of the water in the middle of the slide. I have not been to the pool store since I found this site, and I suspect they may stock what I need, but I thought I would ask here first.
    Thanks!
    18x36, IG, Vinyl, 25,000 gal, S-200, 3/4 Super Pump, BBB or bust!
    I have a new bottom, new plumbing, and everything is working good!
    30,431
    Re: Sliding board lines and fittings
    There is a kit that can be purchased that replaces the hardware on slides. I got it and didn't like it....flimsy parts, etc.
    I chose to go to HD/Lowe's and cobble together the parts I needed to make it work. I think the only things I retained from the old slide were the "nozzles" that produce a flat spray across the surface of the slide.
    I imagine you can find that repair kit online if you choose to go that route.
    Jul 2008
    Pittsburgh, PA
    118
    a slide tubing and fitting kit is less than 20 at the store I work for, it might be worth getting to save the hassle.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
    Riles_J's Avatar
    Nashville, TN
    218
    I had the same problem. I also went to Lowes and got some tubing and related pieces for much less than the kits. However, I can not find the spray caps anywhere. I was not able to reuse mine as they crumbled when I removed them. Anyone have any luck finding these little caps?
    Riles
    16x32 IG vinyl, 19,000 gal, 1.0 hp pump, sand filter, 2 returns, 1 skimmer, diving board, slide
