Thread: Pool drained due to high CH
    I am draining my pool right now because of high CH (800+) and high CYA. I am going to replace some tiles also while empty. I will probably start refilling in two days and hoping to get some advice on what I may need to add as it refills?
    George, Porterville, CA.
    26,000 gl. inground plaster pool with sta-rite 1 1/2 hp pump and sta-rite 300 ft
    cartridge filter 100gpm.
    Re: Pool drained due to high CH
    That depends on your fill water TA and CH levels. The one thing you can be sure of needing is CYA.
