Thread: Shocking
    My CYA is 40 and my shock level is 16 FC . on several occasssion during shocking, I only seem to get it up to about 9 FC before I reach 0.5 or 0.0 CC. Why is that? Should I be getting to 16 FC or is the more important fact 0.0 - 0.5 CC?
    IG 16,000 Gunite,DE Filter, Heater
    Harleysville, PA
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    Re: Shocking
    If you are not reaching 16, you need to keep adding chlorine until you do. What brand of bleach are you using?
    .5 CC is nothing to worry about and normal, you may see it fluctuate between 0 and .5 . We only advise to shock if the CC is above .5 .
    TizMe's Avatar
    Aug 2007
    Covington, Georgia
    Re: Shocking
    also make sure you add all the bleach you need to bring it to 16 ppm. If it calls for 3 jugs for example and them all at once.
    Don't have a pool right now. Just sharing what I have learned over the years!
    Helpful Links:
    Pool School,Pool Calculator,Cl/CYA Shock Chart,TF Test Kit
    Doing BBB and loving it!
