Thread: Bolts + liner =not good?
    Jun 2007
    ct
    6
    I bought a house that already had an above ground pool installed. I have no idea how old it is, but after seeing new pools, I'm sure this one has been around awhile. Last year I noticed a lot of unevenness on the bottom of the pool, lots of pits and craters, and some areas you can feel sharp points sticking up under the liner, like rocks. I'm assuming they either didn't get the ground under the pool prepared well, or there's been erosion, or shifting under the pool...maybe not enough sand under it?
    But when I opened the pool this week, I found something that worries me more. One area along the wall, you can see and feel what must be bolts that connect the parts of the outside wall? It feels like a spine...all the way from top to bottom in a straight line. Did not notice this in previous years. Has anyone seen this happen before, and should I be concerned? I am always paranoid when the kids fool around too much in the pool, because I'm afraid of the old thing caving in, now I will be even more worried, if bolts are pushing through on the liner. I would assume there should be some sort of protection between the wall and the liner, but I have never seen a pool being built, so I can't say for sure.
    I assume there is no fix for this either, other than draining, and taking it apart??
    If that's the case, it would seem wiser to just get a whole new pool, and make sure everything is done right?? Yes, I may be searching for someone to tell me it's time for a nice brand new pool??? 8)
    Shelly
    24 ft AG pool, Hayward DE filter, 1 hp pump
    Would insurance pay for a new pool if that big tree fell in it?
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Bolts + liner =not good?
    The pool liners are very heavy and thick....I wouldn't be too concerned - I can see/feel my bolts where the wall connects too.
    Casey's Avatar
    SW PA
    10,427
    We just had a thread just like this one here.
    cubbybeave08's Avatar
    Feb 2008
    Northwest Indiana
    900
    The pool should have been installed with the heads of the bolts inside the pool...the rounded smooth part...The bolts and the nuts are on the outside of the pool. I can see and feel my bolts to like pool mom said. Not to worry.
    Beave
    Aqua Leader 24ft Round AG Wil-Bar Influence w/54 inch walls 13,500 gallons
    Swimline J-Blue Opal Liner, 1 4X20 Fafco Solar Bear Solar Heater
    Hayward 2 HP Swim Pro Voyager Pump Micro 150 with 4 way timer
    Swim Pro Voyager Filtration System with Hayward ABS Pearl wide mouth skimmer
