Results 1 to 13 of 13
Thread: Yo
    Guest
    Yo
    Hi my name is brett, i've been a pool owner for some time. I work at Leslie's pool doing service for them.
    Arizona
    924
    Hi Brett. Welcome to the forum.
    Buggs
    14,000 gallon, in ground, plaster, free form, play pool.
    Sta-Rite Max-E-Glass with a 1.5 hp Emerson motor
    WaterCo Micron High Rate sand filter S750 490 lb, 4883 sq ft - using ZeoBest
    In floor Polaris cleaning system
    Blue Diamond robot for those after storm days when I can't wait overnight for the in floor to clean it.
    From_Arizona's Avatar
    Glendale, AZ
    212
    Hi Brett - welcome to the forum. Can you tell us a littel about your pool?
    1980's Shasta built 30,000 gal inground diving pool. Pebble-tec interior. Pentair DE Filter. In ground pop-ups. Hayward Navigator sweeper.
    Guest
    Well
    Well my pool was built in the early 80's. Its a 20,000 gallon play pool. 4 Feet on the sides 7 in the middle. I have a nautilus 48 sc ft DE filter (Original) and an aquaflo 1.5 hyp pump and an old Teledyne Lars heater. Everyone looks good. My parents who owned the house and handed it down to me had some crazy pool guy that never took care of the water so I have a pretty bad buildup on the pool. I'm probably going to replace the pump with Hayward's RS series and the filter with a Hayward Progred. Today I just got done pressure washing/acid washing it and I got the tan tint off the walls.I also (about a month ago) replaced all the piping to the pool/spa because of the winter in California freezing the pipes, it took me awhile but hey I'm only one person.
    Welcome to TFP!
    8200 gallon 20' x 48" round vinyl frame pool, manually chlorinated with 10% liquid, salt added to ~2000, 12" sand filter, 1600gph pump, TF100 test kit
    Guest
    Welcome to the forum, brett! I wouldn't advertise the fact that you are one of those dreaded 'pool guys'! We have a bad reputation around here! (just kididng). I am sure your experience in the field will be a valuable asset to the forum!
    Guest
    LOL
    I don't do regular service, I just fix stuff, am I still a "pool guy" with bad rep :P
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: LOL
    Quote Originally Posted by thebrettster
    Welcome. I'm sure your perspective will add a lot to the forum.
    Ft Lauderdale, Florida
    1,455
    Hey Bret,
    Welcome, from another pool guy.
    Attached Files Attached Files
    Sean Assam - Sean@teamhorner.com
    National Accounts and Commercial Products Manager
    AquaCal Heat Pumps www.aquacal.com
    AutoPilot Salt Chlorine Generators www.autopilot.com
    Guest
    Quote Originally Posted by Poolsean
    Sean, Not you also! This place has sure gone downhill with all us pool guys around!
    man, oh man, soon you all will be hawking tri-chlor, SWG's, Frogs, and fairy dust to all of us gullible folk!
    Fayetteville, Arkansas
    220
    Hey Brett. Welcome to the Pool.
    20x40 30,000 gal IG Liner, Pentair II Sand
    1,455
    I'm going to start pitching Leaf Rakes over Leaf Skimmer nets!
    It was the best single piece of pool equipment that helped clean up my pool and my neighbors, after Hurricane Wilma. I was hauling loads of leaves that a skimmer net would have no chance of getting.
    Also, on a day to day basis, the leaf rake does a better job even on surface debris, than a leaf net.
    My Preference? The Red Baron leaf rake!
