Results 1 to 7 of 7
Thread: Filter size, DE to Sand
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    I'm converting my DE filter to sand and thinking about a Hayward Pro-series side mount and was getting conflicting sizes, so I wanted to get your opinions as to the right size. My pool size is about 21k gallons with a 1.5 hp pump, 2" plumbing in and 1 1/2" out. I currently have a 48 sqft DE filter. My first size suggestion came from Leslie's which said I needed at least a S310S, but after reviewing Hayward's pump and filter sizing worksheet (I estimated about 63 total dynamic head and desired flow of about 50 GPM, assuming my values are correct), it seems that S244S or even possible a S210S would work. Given my limited pad size and the considerable increase in $$$ between the S310S and others, I don't want to get more that is needed. My question is which would be best for me (I hope I have given enough info, if not let me know)?
    Effective Turnover
    Model # Sand (lbs) Filtration Area Design Flow 8 hour 10 hour
    S210S 200 2.20 ft2 44 GPM 21120 26400
    S244S 300 3.14 62 29760 37200
    S310S 500 4.91 98 47040 58800
    21k gal, plaster IG pool with spa
    Main - 1 skimmer, 1 main drain, 3 returns, Spa - 1 drain, 4 returns
    WhisperFlo Dual Speed WFDS 1.5 HP pump
    S310S 30" sand filter
    Polaris 360 pressure cleaner
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Filter size, DE to Sand
    You can see my equip. in my signature. I would have went for the 700 lb if I had to do it over again. The bigger the longer between backwash's.
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    30,426
    Match your filter to your pump gpm. You can calc your pump gpm from the manufacturers pump curve (use 50tdh) and then get a filter rated about 20% or more in excess of the gpm's the pump is producing. Shoot back a post if that doesn't make sense.
    Casey's Avatar
    SW PA
    10,450
    I'm just curious as to why you want to switch?
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    There are a few reasons I want to switch. First is the hassle of cleaning the DE filter which means pulling the grids out spraying them off which means me getting soaked and splattered with filthy DE. The grids are very expensive ($60-80$ each x 8) and tend to need replacing every few years it seems like. Plus when I start up the pool each year I can only run for a few hours before having to backwash and load up with DE which is an additional expense. From what I read, I won't have to deal with any of that with a sand filter and it should last longer between backwashes. The reason I started considering it was a comment by my pool guy who replastered my pool and has done some work on my system, who said that when his filter went out he was switching to sand.
    Duraleigh, I think that makes sense. I will look up the pumps specs and see what I find out. Thanks.
    Krickett's Avatar
    Jul 2008
    Arlington, Texas
    82
    I have an issue with figuring out the pump specs. I know the pump is a Hayward Super II, but I'm not sure which model number plus I changed the motor out last year and lowered the hp from 2 to 1.5. Any ideas on how to figure out what spec to use?
    30,426
    That's over my head. Perhaps mas985 will see this and chime in....he's the guru on pumps and water flow.
