Thread: Where do you store your hose between cleanings?
    Exton, PA
    249
    I have the Lil' Shark, so the hose needs to be stright to work properly. The only way I can store it straight is to hang it under the deck.
    I would use a coated hook, so no damage to the hose
    It's under the deck, so out of the sun.
    Rain water would hit it, though the deck would protect it some.
    Will wetting and drying take its toll on the hose?
    Is it better to just store it in the Rubbermaid shed and deal with the "coiling"?
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    Feb 2008
    Denton, TX
    5,061
    Re: Where do you store your hose between cleanings?
    Best to store it stretched out straight rather than coiled. With the sun off of it, oxidation and UV damage isn't such a problem. As for the rain, well, you get it wet anyway when it's in the pool so I wouldn't worry about that so much. When you put in back up for storage, just make sure the water is drained out from it.
    Pool cleaner hoses in general need replacing after a few years as it stands due to UV damage and pool chemical exposure which leads to cracks. I replaced my Baracuda hose when it was about five years old becuase it developed pinholes and small splits in the coils. The fact that you store yours straight and out of the sun will probably make it last longer than most.
    Exton, PA
    249
    thanks
