Results 1 to 10 of 10
Thread: algae problem - getting really frustrated
    Minnesota
    3
    Hello!
    I am fighting algae, have read all you have here. my numbers:
    ph 7.4
    alk 117
    cya 20 (i know its low, i'm working on it)
    fc over 10 ppm
    i have been superchlorinating since thur, 15,000 gal pool, so using 2 gal liq chlorine at night. water was getting blue and cloudy, but everytime i vacumn and brush, it gets greenish again so i am not getting it all. what am i doing wrong, or do i just need to keep at it?
    thanks!
    jlj
    22,000 gallon
    Cristal-Flo™ II 250 lb. sand filter
    30 foot round above ground
    1.5 hp. 12 amp. pump
    TF100 Test Kit
    Re: algae problem - getting really frustrated
    Quote Originally Posted by jlj
    You mean yesterday? I don't guess it matters, the answer is, "Yes, keep going". It can take a while. Keep scrubbing and vacuuming. Backwash or clean the carts when required.
    Some more information like what kind of pool you have, how you are testing, what your CH is, etc. will help some of the experienced members give you more advice.
    Be patient and persistent! Good luck!
    IG ~15,000 Gallon Plaster Pool with Attached Spa
    Hayward SwimClear C4025 - 150GPM, Cartridge
    2hp Pump 1.1 Service Rating
    Direct sunlight most of the day
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    What you need is a little POP (Pool Owner Patience ) It takes time for a pool to become overrun by algae, and time to safely reclaim the pool. Unfortunately, there is no magic chemical that will clear the pool in one dose
    You need to keep the chlorine at shock level for your cya (see the link in my sig) and be persistent and consistent about holding it there Remember to brush the pool so that you are exposing the algae to the chlorine you are adding and get any large organic debris out of the pool ASAP so it doesn't add to the chlorine demand.
    Please keep us informed as to your progress and ask us any questions you have
    Luv& Luk
    -Ted
    Minnesota
    3
    thanks for your responses. i have an above ground pool, vinyl liner, my ch? last time i got it tested it was a little high, but not out of control. i will continue on with my efforts for sure, just wondering if i was on the right track, i have been at this one week, i was not clear when i started in my previous email, i have been using the basic test kit strips, been maintaining a high fc level, dump 2 gal pool chlorine in each night (should it be more?) brush the walls, vacumn when i can to waste, sock full of cya in the skimmer. just keep going huh? i will get there? i have my doubts, but, wanting to actually enjoy the pool this summer i will keep going. please let me know if there is anything i am not doing correct????? ty!!!!
    22,000 gallon
    TF100 Test Kit
    May 2009
    So Cal
    44
    I would highly recomemnd the TF Testkit if you dont already have it, it is very difficult to know where your FC levels are at using any other kit besides the k-2006 or TF Testkit. I am going through that journey now and I bit the bullet and bought the TF Testkit and what a difference. Keep it up and you will succeed.
    15 X 28, 12,000 Gallon, (IG) Freeform Dark Gray Plaster/Gunite with attached 10 X 7 Spa raised 18", 7 Jet with Spillover and Art Rock Waterfall/Grotto, Pentair Intelliflo VS-3050 for Pool, 2 HP Whisperflo for Waterfall/Grotto, Pentair Clean & Clear Cartridge 320, Pentair 400K BTU Matstertemp, Pentair EasyTouch 4P, Pentair Suction Side PoolShark Cleaner, Stenner pump, autofill system, Plumbed for future Solar, TF-Testkit.
    As suggested, the FAS DPD test will help you a lot. When I got my k 2006, I compared its results to the strips and the strips were indicating about 10ppm less FC. My pool had been radioactive with chlorine. Some people report the opposite - the strips show they are at shock and the FAS DPD shows 1 or 2 ppm FC. The OTO test was accurate, but I couldn't distinguish FC from CC and it only went to 5ppm.
    Turning a swamp into a pool can really try your patience. I just recently got my pool swimmable for the first time. It took me about a month, but when I bought my house, the pool had been neglected for a long time - I'm guessing about 2 seasons based on the amount of leaves I pulled off the bottom. It probably won't take you nearly as long.
    Keep it up, keep reading, be patient, and be persistent. Good luck!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Get to know the Pool Calculator, test your water, plug in your gallons, and your current FC (and other) test results and hit calculate, and it tells you how many jugs to add. Without knowing the % strength chlorine you are using, we don't know if 2 jugs is enough or not.
    You can add your pool specs/equip to your Sig. Go to User Control Panel, then Profile, then Edit Signature.
    ivyleager's Avatar
    Sep 2007
    Raleigh-Durham,NC
    489
    I'll add that you need to maintain circulation 24/7 while clearing the algae, and watch your filter presure and backwash/clean fiters/bump (all depending on filtration system).
    You're doing everything right as far as adding bleach only.
    CaryB
    36 x 18 IG vinyl, 25K, 1 HP pump, sand filter
    1 skimmer, 2 returns, no main drain
    Old school: PoolSolutions test kit
    Casey's Avatar
    SW PA
    10,427
    You need a good reliable test kit as mentioned above! The TF-100 get's you more regants and FAST shipping! If you order right now, it'll be shipped today!
    You also need to brush the pool and keep a consistant shock level as mentioned by waste!
    Please add your location and pool specs by using the User Control Panel at the top left of the screen under the TFP logo so we know what you have and where you are without asking you every time you need advice.
    Minnesota
    3
    Good news, my once pea green water is now the most beautiful color blue and very cloudy. So by next weekend, I think we will actually be swimming! Thanks for the advice and the great website - will post a pic when i get a chance!
    22,000 gallon
    TF100 Test Kit
