Thread: Leak where frog hooks to heater
    Our pools guys installed a frog this year (before I came here and found out that it was bad) and they installed it with PVC connecting to the heater. I have a slow drip coming from that connection, how do I fix it?
    Here's a pic, It's right where the elbow joint connects at the heater. I think it's where the gray and white part connect.
    27' round AG, sand, Ohio, well water, 19,000 gallons approx., New owners to the pool.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Leak where frog hooks to heater
    Do you have a shut off valve to keep the water from flowing back thru the return? If you can block the flow of water, see if that's a threaded connection at the heater and try to redo it with some teflon tape....otherwise there is a plumbers putty or pool putty-goop type product that can probably be used but may not work as desired...
