Thread: Partial drain/refill
    I need to do this to lower my CYA. But I'm not sure exactly HOW to do it. Do I set my filter to waste? Will the pump turn off then the water level gets too low? Then I need to refill, recirculate, and then drain again?
    27' round AG, sand, Ohio, well water, 19,000 gallons approx., New owners to the pool.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Partial drain/refill
    Yes, and you should turn it off before it runs dry, and then refill, recirculate, RETEST and maybe repeat.
    hahaha, I'm sure I'll need to do it several times. My CYA was 85 last I checked! Thanks for your help!
    Jan 2009
    Cupertino, CA
    1,966
    So if you're targeting say 60, then you need to replace about 30% of your water or 5700 gal. With a 27' round it looks like you need to lower your water level about 16" if you do it all in one go. If you do it in multiple stages you'd have to replace more water in total.
    Pumping to waste is fast but if you don't have a main drain or can't shut off the skimmer then you won't get all that far. You could siphon with garden hose all you want, it's just going to be a little slower; I suppose you could do several in parallel.
    Where is all this water going? Some jursidictions require that draining a pool has to go into the sewer, not on the ground or street (storm drain).
    --paulr
    BBB "Intermediate Swimmer"
