Thread: Ajax or Softscrub OK?
    Mar 2009
    Charlotte, NC
    539
    My situation: I have some masking tape adhesive to remove from the decorative brick/tile that is between the concrete deck & the water (from a perimeter caulking job so the entire length of the pool).
    I’ve tested various items & know Softscrub will do the job nicely. I’ll have a garden hose to wash it onto the deck & away from the water but some will get in the water.
    I remember as a kid I’d see them cleaning the tiles IN THE WATER with Ajax (so I’m guessing Ajax is ok).
    I haven’t tested Ajax but it’s bound to remove the adhesive too, but it is probably more abrasive than Softscrub & I suppose could scratch the decorative brick/tile so I’d rather go with Softscrub. Is there a good reason to use Ajax instead of Softscrub? Normally I wouldn’t ask such a petty question but I’ve had enough this season with undesirable chemicals in the water. If the deck-tile interface was ideal (sloping away from the water, tile higher than deck) I wouldn’t even ask because I’d be confident it would all wash away, but that isn’t true.
    Thanks
    19,800 gallons (closed/winter 18,654 gal); plaster; 18x34 Ft kidney bean shape, Depth 3Ft-5Ft. Built 1992
    Pentair Whisper Flow Pump 1HP. Winter safety cover w anchors.
    Sand filter, Pentair Sand Dollar Top Mount Model SD80; Effective Filtration Area 3.5SF
    - FlowRate 75GPM, 8Hr 36,000, 10Hr 45,000, 12Hr 54,000; Pressure Weight 50PSI
    BBB (Hayward Chlorinator when leave town). Polaris 360 cleaner.
    Re: Ajax or Softscrub OK?
    Either of those cleansers will require some extra chlorine to clean up and may cause foaming. I would use Goo Gone, it isn't perfect but it should work. You can probably use less to get the same effect and it won't foam up the way the other two will.
    May 2009
    Charlotte, NC
    12
    Hello from another Charlottean on BBB.
    Any solvent will take the adhesive off. However, as Jason said, Goo Gone or "Oops" will work fine. These will evaporate very quickly and leave very little residue. Try it first and make sure they do not affect the color or sealer of the decorative concrete.
    If you're concerned about these chemical residues, , then you could try just a pressure washer ( low psi so as not damage the new caulk) with water and then let the filter take care of any solids.
    Above Ground 14.2 K Gallon, vinyl, Baquapure sand filter, 2.5 HP pump, K-2006 test kit
    grumpy's Avatar
    Jan 2009
    Coastal South Carolina
    64
    Believe it or not olive oil will remove adhesive residue. I've used it on metal, glass and plastic. It may work for you too if your tile is not too porous. All natural too.
    12170 Gallon in ground San Juan Caesar's Palace fiberglass with integral Spa in a screened enclosure. 1 HP Pentair Whisperflow pump with Pentair Sand Dollar SD-80 sand filter. Intellichlor IC40 with EasyTouch wireless remote. Aquacal Heatwave Heat Pump. Taylor K-2006 and Aquachek Salt test strips.
    Mar 2009
    Charlotte, NC
    539
    Thanks & glad I asked.
    I tested Goo Gone or "Oops" etc & decided I didn't want it near or on the caulk( which is also "adhesive" that I want to preserve).
    The low pressure wash is a good idea if i keep it off the caulk. I suspect I'll go w that.
    I'll test the olive oil.
    Anything other than the pressure wash, I'll mop up to remove all possible that way then just hose off the rest.
    BTW, I used masking tape per the instructions, it was a cool 72degrees (max)day in May & not too long in the sun & on the brick less than 3 hours- bummer. Should have used blue painters tape, I hada lot on hand, considered it, but went w the instructions.
    If anyone wants to tackle this "perimeter re-caulking job", I made copious notes that I can refer to the next time I must do this job (something I do for bigger projects, where much is learned, many little details that could be forgotten are involved, & its a project I won't likey have to repeat for many years). Holler if you want them.
    It's an important line of caulk obviously, but especially so if:
    - in drought conditions/after the drought,
    - a cold winter
    - if other cracks in the concrete arent treated
    - there is any non-ideal drainage conditions (water flowing towards the deck instead of draining away)
