Thread: Liquidator adds Cl even when control valve is off?
    May 2008
    Fort Gratiot MI
    66
    I was wondering anyone know if when the control valve for the LQ is off and the flowmeter is showing no flow at all, does the LQ still add Cl into the pool?
    Brian
    24' round Vinyl liner Doughboy 48" deep 52" sidewall
    1hp Doughboy pump w/timer
    Doughboy Silica II filter with Zeosand
    Raypak 180,00 btu heater
    BBB method
    Sundance Optima '97 450 gal. spa w/Delzone ozonator
    Beats driving to the lake, and I'm only a block away from the lake!!
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Re: Liquidator adds Cl even when control valve is off?
    You might get a small amount if the pump is shut off and you don't have check valves on both sides, but not enough to measure.
    May 2008
    Fort Gratiot MI
    66
    Hi John,
    Thanks for the quick reply, I have both check valves on each side and did modify it to the 3/8" line too.
    It must be because it is cooler here still (in the 60's and 75 is few and far between this year so far, its usually close to 80 this time of year, so much for global warming!LOL), and I have my solar cover on almost all the time. Must be it is the combination of the cooler temps and the cover. It just means the Cl I bought (6 cases) will last longer and maybe even into next year!
    Thanks
    Brian
    BBB method
    I noticed mine measures higher than usual (flow set at 1) and pump runs 8hrs/day. I attribute it to the colder weather (no 80's at all) and zero use.
    15,500 gal, inground gunite pool with 7 ft spa, 2 speed pump 2hp/.33hp, 3/4 hp booster pump, Intermatic P1353 timer, AutoPilot SC-48, Sand filter with ZeoBest, Heater, that I never use . . .
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Quote Originally Posted by fixit5561
    Hi John,
    Check your check valves. Hasa's may come DOA new from the box or get biderectional with time. Mine did. I advise you to check rabbit's 3/8" line conversion post and to order the check valves from US Plastic.
    If the control valve is indeed closed and gives 0 flow and the check valves work as they should, I don't see how the LQ can supply FC to the system. Zero feed means zero gain.
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    May 2008
    Fort Gratiot MI
    66
    Quote Originally Posted by Water_man
    Hi John,
    Yes I did convert everything over to 3/8 line last year.
    Yes your right zero is zero but I thought maybe a little got by.
    BBB method
