Results 1 to 8 of 8
Thread: Such thing as liquid stabilizer???
    May 2008
    gulf coast of Texas
    166
    Just wondering if there is a liquid stabilizer? The powder stuff leaves grit at the bottom of the pool and was wondering if there was a liquid forit?
    Julie
    Atlantic Pool Products "Prestige" metal wall pool 18' x 48" round
    vinyl liner
    Hayward Power Flo pump
    Hayward Perflex DE Filter Model EC50AC
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Such thing as liquid stabilizer???
    yes. it's a lot more expensive. but the granular is more or less a one time addition, and it should all dissolve. how are you adding it?
    Rockland County, NY
    52
    Quote Originally Posted by julie492
    Don't let the granules settle to the bottom of the pool, you are asking for trouble if you do. Undissolved chemicals that settle to the bottom will almost certainly create problems for the liner. Apply the granules in small batches through the skimmer using a filter sock to allow the granules to dissolve gradually while running the filter 24/7 until all the granules are thoroughly dissolved.
    22,000 gallon ig vinyl solar heated (panels and cover) zeolite filtrate
    Jan 2009
    Cupertino, CA
    1,966
    So, you should vaccuum the "grit" into the filter to get it off the liner. Or at least brush, if you don't have a vaccuum. Do Intex pools have a main drain? You could brush it into the drain if so.
    --paulr
    BBB "Intermediate Swimmer"
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    I was looking into liquid stabilizer as well. Found it here http://www.intheswim.com/Pool-Chemicals ... r/#reviews
    Part of the reason is because I don't need a lot. I keep my stabilizer level around 35 and have borates slightly over 50ppm. CYA has dropped to about 25 from an accidental high of 50 (lots of rain over the winter), so it is time for a little CYA- about 1 lb crystals or 1/2 gallon liquid according to pool calc. The smallest I can get in crystals is 4lbs. In the liquid I can get 1 gallon. Will the liquid last for a while if I add half now and half later? How long will it stay stable(up to a year)?
    28 ft round Doughboy Sand Dollar II AGP, Aug 2008: 4 ft shallow, 6ft deep end: 24K gal approx Hayward Power-Flo Matrix
    1&1/2-HP 2-SPD Pump, Hayward 27-Inch Sand Filter with a little DE -(2) 4ftx20ft Solar Bear AGP Panels w/ Goldline auto-controller, 50ppm Borates And some day, maybe this year, a DECK!!!
    Mar 2007
    San Rafael, CA USA
    12,082
    I checked with the inventor of Instant Pool Water Conditioner and he said there is a preservative in the product so it should have at least a 2-year shelf life.
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    Good to know- thank you chem geek.
    amjohn's Avatar
    Jul 2008
    Rural NE Texas
    389
    I got some from Intheswim. Not as sludgy as some of the reviews on the website suggested, but then it sat out in 100 degree heat all morning before I finally won the game "Find where in your yard UPS has hidden your packages this time".
    My CYA test down around 20 this morning, and I am burning through the bleach with the 100 degree heat and intense sun, so it is time to add more stabilizer. It dissolved well enough by dribbling slowly in front of the return. A few little bits had to be brushed up. The product apparently has a "salt-friendly" pH, whatever that is, so I may have to make some adjustments. My pH and TA have risen some in the last couple weeks- the pH I know is from aerating to cool the pool, not so sure about the reason for the TA.
