Thread: Question on liner wrinkles. Beam gap.
    Exton, PA
    249
    Our first ABG pool and we had it installed, mostly due to the amount of ground needed to be removed, etc. Anyway, are wrinkles on the bottom acceptable? If so, how many (hard to answer I know)?
    18' x 52" round pool
    The installer did push out wrinkles and used the vacuum, etc., but left when the pool was hardly filled. Now I see a couple issues:
    The wrinkles on the bottom.
    And, the skimmer is on the same wall portion as the seam (bad design by manufacturuer). So the skimmer was sagging (pushing wall in) up until the pool was almost filled. However, the seam of the wall is not making full contact with the support beam. I was able to fit all fingers laying flat between the beam and the wall. Now I can slip only my pinky up to the first knuckle. Is this a problem?
    Installer is returnign today to address pump fitting leaks, etc. so any help you can provide is greatly appreciated.
    thanks!
    18' AG pool, 7,646 gallons, Sun from 11:30AM-2PM.
    Pentair Dynamo 1hp pump, Intermatic Timer (6/17)
    Pentair Sand dollar filter - 100lbs, 35gpm
    Pentair Lil' Shark cleaner, TF-100 Kit
    Raypak 206A 200K, BTU gas (6/17)
    delfargo's Avatar
    May 2008
    some cornfield in central illinois
    86
    Re: Question on liner wrinkles. Beam gap.
    as far as the wrinkles... i've had plenty of wrinkles on the bottom of mine since we put it up 4 years ago and have had no problems. i was told that the liner might wear out faster where the wrinkles are, and maybe i should try to smooth it out. but in order to do so, i'd have to drain the pool, so i'm not too worried about it.
    the beam gap problem should fix itself when the pool is fully filled. the weight of the water pushing against the wall should take care of it, i would think.
    30' round above ground - 21000 gal. (shade ONLY in the evening),
    pentair dynamo 1.5 hp pump,
    pentair sand dollar 150 lb.sand filter,
    bbb method.
    Exton, PA
    249
    Thanks, but the pool is filled an the gap, though smaller, is still present.
    Also, I hear you about the wrinkles. However, we installed a 15 foot pool for a friend and we had only one small wrinkle.
    The main reason I hired these guys was due to the amount of dirt that needed to be removed for install and the 7 tons of stone we wanted to surround the pool.
    Having paid "professionals" to install the pool, should I not insist that the wrinkles be removed.
    delfargo's Avatar
    May 2008
    86
    you are correct. if you paid someone to install it, then they should get it right and you should insist they smooth it out and correct the beam gap. i only have myself and some friends to blame for the flaws in my pool, but, yeah, you're paying for the job to get done right, so they should fix it.
    bbb method.
    Exton, PA
    249
    Agreed.
    We installed a pool for my friend about a month ago. It went well, except they sent us the wrong liner clips. We use a Dewalt cordless remote laser level. Unbelievably accurate. a week after we installed the pool, his brother-in-law was installing a deck and rechecked the pool for level. Within an 1/8". I actually used a string level to check mine after install, before filling, and it was 1/8" as well.
    I setn you a PM regarding your equipment. Ours is almost identical and was just curious how you're liking it.
    thanks
