Page 1 of 2 12 LastLast
Results 1 to 20 of 25
Thread: some questions about being a new pool owner and starting bbb
    i was given an intex metal pool 15 feet 4 feet deep has been nothing but ****.had water delvered twice and had to drain it because pool was uneven,third time was the charm and pool is even to save money used my well water MISTAKE hit it with chlorine and now its brown i have been filtering non stop and used metal out today pool lady said will take 24 hrs and might need more,i will know in the am.now if it works how much bleach should i start with and how long after metal out.also i have a floatie thing that holds cholorine tabs can i put that in the pool with the bleach?the borax and arm and hammer same questions above how much and safety with floatie thing.also any other hints ect oh yeah my little test kit will it work for the bleach and borax.please any help will be appreciated i never thought having a pool would be so hard,with all the bad luck im having next thing the pool will cave in lol thanks traci
    Round intex 16 foot x 4 foot deep Eastern Pennsylvania just the basic crappy intex pump that comes with pool
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: some questions about being a new pool owner and starting bbb
    Welcome to TFP
    The first thing you need to do is test your water. The only things you can be sure of needing without a test are chlorine and CYA. I wouldn't count on the floater for much help. They don't deliver chlorine fast enough to keep up with demand.
    Thank you I will go today when they open and post the results also since using the metalmagnet alot of brown rusty debris is going to the bottom and I have to vacuum it out.problem is I have to use the hose vacuum intex pumps don't have an intachment so won't that keep blowing iron back into the pool so I will keep getting brown water do you think I put a sock or a stocking over the hose like put over the skimmer to catch the rust particles or whatever they are iron particles would that catch the iron before blowing into the water or are they to small before the metalmagnet is placed in. I'm sorry for being a pain but I'm am so confused and if not for my 12yr old daughter really excited about having a pool I think I would of gave up thank you again traci
    This sight is great
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    You need to ideally, figure out a way to vacume the particles out of the water, bypassing the filter or "vacuming to waste".
    Also, you won't necessarily need baking soda or borax, we need to see your water test results first. Sometimes the fill water is okay on PH and TA and they don't need adjusting at all.
    Welcome to TFP!
    Guest
    First thing, take a deep breath! We are here to help you!
    Second thing, click on the pool school link in the upper corner of every page.
    Read EVERYTHING there.
    Read it all a second time.
    When you are done, post questions about anything you understand. Once you have the basics of pool school under your belt you will find that it's all a LOT easier than you think!
    hello,I took the water to the pool place they said everything was in normal limits just doesn't have chlorine. They gave me another botttle of metal magnet and said to use that filter filter filter and vacuum then to start to add cholrine tommorrow night.can I start with clorox instead if so how much and how often also should I put the floatie with the chlorine tab in it will that be dangerous thanks traci
    11,969
    Did they give you the printout of test results? Telling you it's Normal doesn't mean much....
    "start with clorox instead" - instead of what?
    Jan 2009
    Cupertino, CA
    1,966
    Use bleach to get your chlorine level up fast. Also you need stabilizer aka cyanuric acid to protect the chlorine from the sun. Tabs have both chlorine and stabilizer but not much all at once, and you need a bunch all at once.
    --paulr
    BBB "Intermediate Swimmer"
    Hello,I finally I think got all the iron out now pool is a sea green I have some water results so here they are stabilizer very low 0 /total alkalinity low 40/ ph low 6.8/bromine ok 2/free chlorine ok 1/ total chlorine ok 1/total hardness high 250 I hope this helps I'm not sure what to do now thanks traci
    11,969
    Quote Originally Posted by vettechgirl
    Ignore references to bromine, because you have a chlorine pool.
    You need to raise your PH up to 7.2 and also your TA, both are too low. For the PH/TA you will probably need a combination of borax or Soda ash for the PH and baking soda for the TA. You need to add CYA (stabilizer) to your water to protect your chlorine. And then you need to add chlorine daily.
    Use the Pool Calculator to figure out how much of each product you need.
    Refer to "Recommended Levels" in Pool School.
    If you have a hard time figuring out the Pool Calculator, let us know, but you need to learn how to use it for daily bleach and/or chemical additions.
    How are you testing? You really need one of the recommended kits....
    Sorry I bought my borax and baking soda but I can't figure out the pool calculator please help thanks
    Have you read the article in Pool School on how to use the Pool Calculator?
    Yes I read pool school twice. I did get measurements but don't trust myself I think I got 4.4ozfor borax and12oz for baking soda thanks
    Starting with a TA of 40, I would add two pounds of baking soda, let it mix in for an hour and then test again to see where you are.
    Thank you I was way off I will try that and let you know can it be during the day or do I wait for evening and should place in skimmer thanks so much you guys are great
    You can add baking soda at any time of day. Baking soda can be pre-dissolved and then poured in or spread across the surface of the pool.
    Hello I'm getting there thanks to all your help this is a great site. My readings now are from dipsticks from aquachem all I can get at this time stabilizer 0 very low (they didn't have any at Walmart when I went last night for the borax and baking soda pool store won't be open until tommorrow)total alk 120 ok/. Ph 7.2 ok/. fch 1 ok/. Tch 1 ok// total hardness 100 low. There is still a light green tint should I put alge stuff in? Also my pool Is in total sun I can't figure out how to get back to my signature so I can put that thanks again for all this help
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    the only algae stuff you need is chlorine and yours is really low. you need a good test kit or this is going to turn into a never ending cycle.
    Yes I agree but all I have is this for right now I will get better test strips within the next week or so also is the pool ok to swim in yet thanks traci
  20. Back To Top    #20
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    there are no better test strips. there are the recommended kits in pool school or a never ending cycle. I've been there done that for almost 4 years before I found this site.
    I don't think you'll die from it, but my guess is no one here would swim in it.
