Thread: Dead Motor? What should I do with it now?
    Jan 2009
    Plano, Texas
    19
    A few months ago I replaced this dead 2 HP motor and it has been sitting in my garage ever since then.... I don't know how bad it is and the burnt wires are hard to see in the pics...
    1. can anything useful be done with it? (e.g. can someone refurb or fix it)
    2. if not, anything I can do with it other than just throwing it in the trash?
    thanks!
    frankthailand's Avatar
    Apr 2008
    Thailand
    152
    Re: Dead Motor? What should I do with it now?
    there is a lot of copper in there surely it can be droped off somewhere and be recyled.
    Hello all from the land of smiles. Thailand. 5mx9mx1.5 63000L 16300 gall, pebbletex,
    pentair 1hp whisperflow, tagelus TA60 SF, swg monarch esc24 {a bit small for the tropics} 3 returns, 1 skimmer, 2 astral 100watt lights. Planned and built by me
    an AUSSIE expat living thailand for 18 years.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Look up electric motor repair in your phone book. May be under starter/alternator repair. They are pretty simple to repair usually.
    spishex's Avatar
    Oct 2008
    Hillsborough, NC
    1,375
    Most metal recyclers only take motors (to buy) in bulk, and they fetch around $.05/lb these days. There are other recycling centers around here that will accept them. Call your local landfill and they may be able to help.
    Apr 2009
    Central Minnesota
    74
    Take it to your local motor repair place. If it is cheap enough to repair, you might want to consider that so you have a spare. If it is not worth repairing, then the motor repair place will take it off your hands and recycle it.
    18' X 36' X 4.5' vinyl oval in-ground 17K gallons, 250K BTU Pentair Master Temp NG heater, 1HP Hayward Super Pump, Hayward S200 sand filter, Hayward Pool Vac, Extreme mesh safety cover, TF-100 test kit.
