Results 1 to 7 of 7
Thread: Do I need an eyeball return?
    Mar 2009
    NJ
    215
    I have a regular, straight return with no option to move it around in any direction? Should I get a replacement, or do I not need it? I've read many times of people having to "aim" their return up or down for various reasons.
    I have an 18' round AG pool with just that one return.
    18' x 54" Round AG 7500 gallon w/small prefab 2-piece fandeck
    Waterways 200sf Cartridge Filter, 1.5 hp 2-speed pump. 2" pvc piping
    Pool Pilot Total Control swg w/acid tank feeder
    Pool Rover Jr., BBB, TF 100 test kit
    May 2009
    Jasper, TN
    249
    Re: Do I need an eyeball return?
    Wow, I came to post the exact same question.
    I have one return with nothing attached. I'm afraid my skimmer is not working as well as it could since the return is near the skimmer and it looks like it pushes most of the water from the skimmer.
    24' x 52" AGP = 13.5k gallons
    Dynamo 2.0 HP pump,Sand Dollar sand filter
    Polaris 65 vacuum (good when there are a ton of leaves on bottom), Pool Rover Jr. (LOVE it, but power box dead right now), AquaCritter (an excellent suction side cleaner)
    Jul 2008
    Pittsburgh, PA
    118
    The eyeballs help by focusing and directing the water. Its only a few bucks, I would probobly buy them. Its not going to do any damage or anything not having them.
    Matthew
    Involved in the pool and spa industry
    Pittsburgh, PA
    Mar 2009
    NJ
    215
    Thanks.
    I'm currently just under the skimmer/return line of filling my pool. I have to plumb it before going any further. I don't think I can get an eyeball delivered in time for that, so I'll have to go to the local pool store. Not sure if they sell those things at a Leslie's or not.
    Thanks again for both replies. Maybe I should try and avoid your issues, rastoma. I hear people turning the eyeball for aeration and other things, so it may be best to wait and get it now. Good luck.
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    aimable eyeballs do help. I've got two returns and have both returns pointed to the right and down (my skimmer is to the left of the returns). Makes all of the debris in the bottom of the pool end up in the middle for easier cleaning, and also helps the skimmer skim more effectively by having the water rotate by it. Just my .02.
    24' x 52" AGP - approx 13,500 gallons
    Pentair Optiflo 1 hp/2sp pump w/ Swimpro Voyager 150 sq ft cartridge filter
    Intex 8110 SWCG
    "Fear the Schnauz!"
    Mar 2009
    NJ
    215
    Boy do I feel stupid. I called the company where I bought the pool to ask what size eyeball I need. Long story short.... I have one installed there already. oops.
    So, should I point it down and away from the skimmer to make the water go in a circular motion? If I need to aerate, just point it up? The gentleman on the phone said not to turn it until I loosened the locknut (or plate or washer that holds it together??) first. Do I have to do this every time I turn it a different direction?
    MikeInTN's Avatar
    Middle Tennessee
    1,335
    Depends on how tightly the faceplate is screwed down. It uses a friction between the eyeball and the faceplate to keep the eyeball pointed where you want it. The faceplate should be threaded on, so it's no biggie to loosen it slightly and then retighten after re-aiming your eyeball.
    Intex 8110 SWCG
    "Fear the Schnauz!"
