Thread: pH test kits that remove Cl?
    In dealing with my ongoing trials in testing pH and Cl with 'color vials' provided in TF kit, I came across something I don't understand. I have a test kit similar to the TF for testing pH and Cl that came with our pool. It all looks the same, however in the 'pool' kit, before you add the reagent to change the color to indicate the pH level, you first add another reagent that says it's designed to 'remove' Cl first before testing. Yet the TF kit skips that step. Is the removal or not of the Cl important in testing pH?
    22,500 gal A.G., vinyl, sta rite crystal sand filter- Pentair Water Pool & Spa , Hayward Super Pump Self Priming 10" lift, BBB method
    30,421
    Re: pH test kits that remove Cl?
    The OTO test kit in the TF-100 doesn't change color. You simply add five drops and read the resulting color. It is a comparison test.
    What test kit do you have?
    Removing chlorine is important for doing the PH test. The Taylor PH reagent, included in the TF100, already includes an much more effective chlorine removal chemical than the ones that come in the kits where you need to add it separately.
    Ok, that makes sense, Jasonlion..that the Cl remover is already included in the TF kit whereas it comes separate in the kit that comes standard with the pool when we bought it (pool). And yes, I understand what you mean, duraleigh, about the comparison...but I guess in my feeble mind..it does in a sense 'change' color...it goes from clear to some other color...whether it be orangish or red... I know, not very scientific! Thanks to you both!
