Thread: chlorine & biofilms
    May 2009
    Dallas, TX
    785
    chlorine & biofilms
    I thought of a question today while brushing my pool: If I keep my FC level at or above the min for my CYA concentration, is that enough to keep any biofilms from forming in my pool, or is regular brushing necessary to disrupt any biofilm from forming?
    Dave
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: chlorine & biofilms
    I don't know about biofilm (what is that?) but regular brushing is needed to prevent algae.
    Mar 2007
    San Rafael, CA USA
    12,082
    Biofilm is a colony of bacteria that is attached to a surface and has secreted chemical substances to the outer surface of the outer cells to make them more resistant to chemical attack. Usually such substances have a slimy feel.
    Keeping the chlorine at a proper level will help prevent biofilm formation by killing bacteria before they are able to reproduce and secrete the substances that make them more resistant to chlorine. Nevertheless, brushing helps as well, especially for surfaces that are pocked so could result in very localized low-chlorine levels or in areas of the pool where circulation is poor.
