Results 1 to 9 of 9
Thread: Who to believe
    Who to believe
    First test with TF100 CH 400 - as a double check had pool place test water they said I need to add 10 pounds of calcium?
    Here are the details:
    17K gal
    DE filter
    AG
    MY RESULTS:
    FC 27
    CC 0
    TC 27
    pH 7.2
    T/A 200
    CH 400
    CYA 85
    I shocked pool yesterday.
    Caretaker for:
    24k gal fiberglass IGP Big Blue Key by Blue Hawaiian, Hayward sand filter 200lb, 3/4 HP pump, power cover.
    Re: Who to believe
    Did the pool store actually tell you what their result was for their test?
    If I were you, I would test it myself one more time and if it still read that high, take a sample to another pool store for testing.
    Have you been getting calcium scaling or build up anywhere?
    IG ~15,000 Gallon Plaster Pool with Attached Spa
    Hayward SwimClear C4025 - 150GPM, Cartridge
    2hp Pump 1.1 Service Rating
    Direct sunlight most of the day
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Who to believe
    above ground means vinyl so your problem with high ch would be scaling. but your ph is on the low end so I doubt you're having that problem. you don't have a salt water generator do you?
    p.s. believe your results. my ch is 625 but the pool stores always tell me it's 400.
    Jan 2009
    Cupertino, CA
    1,966
    Re: Who to believe
    Don't believe the pH when FC is that high.
    What was the reason for shocking?
    --paulr
    BBB "Intermediate Swimmer"
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    Re: Who to believe
    good catch. I saw a post from JasonLion that said high fc makes ph read falsely high. I can't find it now, but fpm says it in this thread, near the end.
    low-ph-high-ta-almost-zero-fc-help-t12923.html
    Mar 2007
    San Rafael, CA USA
    12,082
    Re: Who to believe
    First off, welcome to TFP!
    For sure with the high CH you do not want to add more calcium which is what the pool store said to do -- at least if you CH reading is correct. 10 pounds of calcium hardness increaser would raise the CH by 48 to 64 ppm depending on the type of calcium chloride that is used. It sounds like they think your CH is somewhere around 250 and are thinking it should be 300, but that's just a guess on my part.
    Re: Who to believe
    Quote Originally Posted by PaulR
    --paulr
    I just opened the pool
    Caretaker for:
    Jan 2009
    Cupertino, CA
    1,966
    Re: Who to believe
    So, the water is clear? Excellent.
    I hope you're using liquid chlorine or bleach; your calcium and CYA levels are too high to want to use anything else.
    --paulr
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Re: Who to believe
    Calcium levels as low as 50 are perfectly fine for an above ground pool. They are just trying to sell you chemicals.
    Have you read Pool School?
