Thread: Question on in-line chlorine feeder
    I have been reading over this board for a couple of weeks or so. I think we are now ready to purchase an above ground 24' pool. The package I am leaning toward includes an in-line chlorine feeder. Since I plan to use the BBB method, is this something I would use going forward? Not sure if any of the chlorine tabs are available that would not increase the CYA. At least I think that is what they increase.
    Thanks for any help.
    Edd
    DaveNJ's Avatar
    Toms River, NJ
    520
    Re: Question on in-line chlorine feeder
    Welcome to TFP,
    It would be good to use if your going to be away, vacation. This thread discusses Cl feeders.
    looking-for-a-new-chlorine-option-t13601.html
    IG 18x36 oval vinyl, Spill over spa, Northstar 2hp-2spd, 2.5" piping, S310T 500lb Sand filter, 400k gas heater, AutoPilot SWCG
    http://www.tftestkits.net/
    Hi, Edd,
    Welcome to TFP!
    You are correct that tabs (or pucks) raise CYA. For short-term use, they are fine, IF you know your water chemistry.
    8200 gallon 20' x 48" round vinyl frame pool,
    Intex SWCG, 12" sand filter, 1600gph pump, TF100 test kit
