Thread: Which should be done first?
    Mar 2009
    Galveston, Tx
    16
    Readings today:
    FC 3
    CC 0
    TC 3
    ph 7.8
    TA 150
    CYA 90
    I am finally getting around to working with the pool water balance. I know I need to keep the TC 7 - 10. Momentary lapse, I'll do better. Historically I had used Trichlor Tabs, until if discovered the BBB method. Both TA and CYA are elevated, so does it matter which I do first? Does lowering the water level and refilling to lower the CYA have any impact on the TA?
    23 K Gal
    DE
    IG
    gunite
    2 Hp Pentair pump
    Filter: DE Nautilis FNS 60
    Jan 2009
    Cupertino, CA
    1,966
    Re: Which should be done first?
    Quote Originally Posted by mcase
    That depends on the TA of your fill water. It works for CYA because the fill water will certainly have zero CYA.
    But, since you have to replace water to lower the CYA anyhow, you just do that first and then retest to see where you are with pH and TA. Fixing up the TA first is just a waste of chems.
    --paulr
    BBB "Intermediate Swimmer"
    If you are not having chlorine problems...you may consider leaving the CYA alone...just be aware of where your "shock" and minimum chlorine levels are...and dose accordingly
    Since your pH is also 7.8...I would lower the pH to 7.2 (but no lower) and let it creep up with your bleach addition...your areation should increase with pool use now that we are getting into the summer and this will raise your pH also...
    EDIT.. FIXED....my original edit needed proofed as I failed to delete the end of the sentence...the concept that I was trying to convey to the OP was that there will be two forces that will tend to increase the pH...the addition of bleach and the areation...so I would suggest targeting the lower range of the pH as it tend to drift upward....
    25,000 gal IG Utopia pool/Raypack gas heater/BBB
    Butterfly's Avatar
    South Carolina
    10,045
    Since your pH is also 7.8...I would lower the pH to 7.2 (but no lower) and let it creep up with your bleach addition...your areation should increase with pool use now that we are getting into the summer and this will help lower your TA...
    Ah, aeration raises pH. Muriatic Acid lowers TA and pH. (more details in Pool School)
    You're done SLAMing when:
    Jan 2009
    Cupertino, CA
    1,966
    Quote Originally Posted by ideliver
    Even in Texas, CYA 90 seems a bit much for a bleach pool.
    --paulr
    Quote Originally Posted by PaulR
    --paulr
    ...as long as he is aware of the risks...and is aware of the FC/CYA chart..
