Thread: Question about CYA
    Sep 2007
    Question about CYA
    I was adding CYA granules into the pool. I followed the instruction by pouring the granules down the skimmer. Later on, the pool store guy said I should have used a sock instead. I have a cartridge filter and now all the granules are probably lodged at the filter. Will it eventually dissolve? I did an experiment by putting a teaspoon of CYA into a cup of water, despite vigorous stirring, the granules are still there a few hours later. I have test strips that also test for CYA but I am not getting meaningful readings.
    San Juan 8500 gal Fiberglass Pool, Sta-Rite Max-E 1 HP pump, Star-Rite System 3 Cartridge Filter 300 sq. ft,
    Sta-Rite Max-E 200,000 BTU gas heater, Aqua Logic SWG with P-4 panel. Goldline wireless remote control,
    3 Jandy Neverlube Valves with Goldline motorized control, iRobot Verro 500 pool cleaner
    5 Poolstar 1000 LED Lights, LED strip light at waterfall, Prozone Ozonator PZ7 with degasser column,
    Jandy Auto Waterfill, Aquamatic motorized pool cover, Poolbuster Max CC handheld vacuum.
    Re: Question about CYA
    Adding CYA through the skimmer is just fine. We also tend to recommend using a sock, but there is nothing wrong with putting it in the skimmer. You should run the pump for 24 hours after adding CYA and don't clean the filter for a week.
