Thread: Hello - from TexasCruiser, a new forum member from N Texas
    Just dropping a line to say hello. Once I get the feel for this, you will most likely be hearing from me again and again.
    Ok, I am adding to this post .... I am starting to believe first order of business is a good test kit to replace that HTH test strip kit from Walmart
    15'X48" Intex Frame - 4,400 gallons, with the standard craptacular pump/filter.
    May 2009
    Dallas, TX
    785
    Re: Hello - from TexasCruiser, a new forum member from N Texas
    Quote Originally Posted by TexasCruiser
    Welcome to the forum from another newb!
    Dave
    20K gal IG plaster pool, Manually chlorinated with bleach, 1.5 HP Sta-Rite Dura-Glas II pump, Pentair FNS Plus 48 DE filter, Polaris 280
    Hello Dave (neighbor) - you are probably only about 70 miles or so from me if you are in Dallas area
    Butterfly's Avatar
    South Carolina
    10,045
    You can join the long member list of Texans we already have
    We're glad to have you.
    You're done SLAMing when:
