Results 1 to 9 of 9
Thread: Water Tested now WHAT?
    Apr 2008
    North Carolina
    10
    Free Chlorine .5
    Total Alkalinity 237
    pH Level 7.9
    Calcium Hardness 150
    Cyanuric Acid 15
    24' Round 52" OG, new vinyl liner, 1 1/2HP pump using sand filter
    30,432
    Re: Water Tested now WHAT?
    What are you trying to accomplish? Do you have green water? Cloudy water?
    Mar 2007
    Coastalish 'down easter'
    4,160
    Welcome to TFP!!
    Duraliegh raises a good question - however, you still need to up the chlorine and cya.
    Also, you'll have an easier time of maintaining the pool if you get your own test kit - those numbers were generated at a pool store
    Luv& Luk
    -Ted
    Jan 2009
    Cupertino, CA
    1,966
    pH looks to be on the high side too.
    --paulr
    BBB "Intermediate Swimmer"
    Apr 2008
    North Carolina
    10
    Water is a bit cloudy, I can see the bottom.
    Need advice on what to adjust first.
    I have my own test kit but I use the pool store as a back up.
    30,432
    1. Lower your pH to 7.4
    2. Bring your FC up to 12+ppm and keep it there until the water is clear.
    3. Add enough CYA to get to 40ppm.
    Apr 2008
    North Carolina
    10
    CYA is stabilizer, right?
    Having a hard time finding any right now.
    Yes, CYA is stabilizer, and is also sometimes called conditioner and/or cyanuric acid.
    reebok's Avatar
    Apr 2009
    Lakeland, FL
    1,268
    if you have a pool store they should definitely have it. you can try lowes, home depot or walmart also. you can also order it online. with low cya, your chlorine will be destroyed(?) by the sun really quickly.
