Page 1 of 2 12 LastLast
Results 1 to 20 of 26
Thread: Adding salt: why did my level go too high?
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    This is my second season in "the program". After regular water adjustment and sanitation has become like a second nature, I decided this season to have top quality water by adding borates and salt, trusting positive reports from other users regarding these two chemicals in their proper dosage. I did a bucket test and couldn't taste salt at 3000 ppm.
    I added borates to 50 ppm using the dosage calculated by Jason and chem geek (93 w% Boric Acid and 7 w% Borax.) I checked the level with LaMotte insta - test strips and I got it right.
    I checked my pre-existing salt level with Aquacheck's salt test strips. I got 500 ppm. According to the pool calculator, adding 400 Lbs of salt should raise the level to 2634. However, after adding 400 Lbs I got 3820 ppm and I can certainly taste some salt. What happened?
    This is my ticket for Heaven (when all's working..) :
    22k Gal gunite IGP, 38 SF Anthony DE filter, 1 HP Hayward Super Pump
    380k BTU Raypak Natural Gas Heater (Model RP405A) and solar cover
    8 gal Liquidator w/ 12% bleach, Dolphin Diagnostic Advantage robotic cleaner. 3800 ppm salt, 50 ppm borates.
    no-mas's Avatar
    Jun 2008
    FL
    405
    Re: Adding salt: why did my level go too high?
    Maybe your pool holds less water than you think?
    18k gal inground, everbrite finish, 505 sq ft; 1.5 hp two speed whisperflow; rheem 5100ti 100k btu heat pump; 3 sheer descent falls; DE filter; swg (cell out and using trichlor for now)
    Mod Squad JohnT's Avatar
    SW Indiana
    9,198
    Quote Originally Posted by Water_man
    You are usually better off adding partial doses then remeasuring when you need to add a lot. Half the first time and wait to measure the result, then half the remainder until you get a good handle on how much you need to add. In your case, I'd have added 200lbs, remeasured, recalculated the amount I thought I need to get where I wanted, then add half again. By then, you'd have a pretty good idea how much it was going to take to get right where you needed. The most likely problem would be a mis-estimation of the pool volume.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    All other chem additions came up right, based on the pool volume I have.
    My pool volume couldn't be wrong by 52%, as implied by the different salt levels.
    mas985's Avatar
    Pleasanton, CA
    11,737
    How long did you wait before testing? Sometimes it takes a while before the salt fully mixes with the water. Wait a couple of days and check it again.
    Mark
    SW Indiana
    9,198
    Well, 22,000 gallons is 183,480lbs of water. 400lbs of salt would add 2180ppm to 22K gallons of water. Math gets the same answer as the calculator.
    Three options: Your pool really holds 14,400 gallons (unlikely). Original reading was wrong and it was really ~1600ppm (never used salt strips, so I don't know if it's possible to do it wrong), or you really added ~600lbs of salt. Not likely either unless you are a really bad counter
    We need a "Scratching My Head" smiley!
    We do
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Maybe Diamond Crystal had a promo: "Buy a 40 lb salt bag and get extra 20 lb salt for free in the bag!" Who knows? It's very unlikely that I had 1600 ppm before the addition, and I definitely added 10 bags. The good news: Next season, after winter dilution, it will be perfect.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Quote Originally Posted by mas985
    I see a light of hope here. I added on Sunday and checked after one day.
    I'll wait one more day.
    It seems really unlikely, but they also sell 80 lb bags. My local Home Depot only has 80 lb bags, while Lowes has the 40 lb bags.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    I got it at Lowe's . It's 40. I don't like the test strips. The yellow strip at the top never gets really dark. Does anybody know a different brand? What's the most common brand used by those who have an SWG pool?
    AquaChek are the best available method for testing salt. The only reasonable alternative is the Taylor chloride test kit, which is somewhat complex to use and can cause stains.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Then I'm really baffled. What the hack. I wish that were my only problem
    Guest
    Are you sure you added 40 lb bags? Diamond Cryatal also makes a 60 lb bag. My local Lowes and Home Depot carries both sizes. In fact, I just bought 2 60 lb bags of Diamond Crystal.
    If it's not a measuring error it's a testing error.
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Still have the empty bags. 40 Lbs. What's the chance that a non SWG pool, that gets 25% dilution every year, will start before salt addition at 1600 ppm salt? It's an unsolved mystery. Maybe I should try another batch of salt measuring sticks. Instructions say "white peak". The bottom light strip that develops after 5 minutes is never white. It's light yellow. Will posting a pic of a developed strip be worthwhile?
    Guest
    It is possible to start with that much salt if the pool has been in operation for a while. If you have verified that they were 40 lb bags I would have to say that you did the salt test wrong the first time. Not an unusual thng for the first time doing a test. Use only 1 inch of water in a container, let the strip sit in it a minimum of 5 minutes until the bar at the top darkens and there is no more movement of the light strip over a 1 minute interval.
    Jul 2008
    Dallas, Tx
    128
    I experienced a similar situation this year. Started w/ ~1200 ppm salt (1170 my Aquachek test, 1200 pool store test with different water sample), added 160lb Diamond Crystal from Lowes (four 40 lb bags), tested 2 days later (today) and came up with 2830 ppm.
    According to the pool calculator 160 lbs should have put me at 2300 ppm (17,500 gal). Although my calculation of the pool volume could be off slightly, it's definitely not 12,000- other chems behave as expected for 17,500 gallons. For me, the extra salt will end up being lost in backwashes, splash out, etc. so I'm not worried about it, just thought I'd chime in and say, me too.
    20k white plaster with blue quartz, IntelliFlo VS, Quad DE 100
    1000 gal spa with natural stone waterfall
    Beach entry with 2 bubblers. Pool built Spring 2013
    Water_man's Avatar
    Jun 2008
    Brookline, MA
    390
    Hi Terry, thanks for joining the club
    What did you use for testing your salt?
    May 2009
    Trenton NJ
    497
    I have a zodiac swg and the salt requirement chart it came with states at 500ppm if you add 407 lbs of salt you will be at 4000ppm,which is optimum for this swg.
    20,000 gallon viking fiberglass pool w/aqua comfort heat pump, pentair whisperflo pump 1.5hp autopilot dig-220 swg w/RC42 cell (42,000), pg2000 fiber optic lights
    hayward sand filter(medium is echoglass)
    Blue diamond robot cleaner
  20. Back To Top    #20
    May 2009
    Trenton NJ
    497
    And this is with a 20,000 gallon pool
