Thread: Pentair Easy touch and Solar control
    Im getting the Pentair Easy touch with 8 aux for my new build IG pool.
    from the instuction manual there seem to be controls for Solar valves. There is a solar sensor input. Where do you find the sensor. cant seem to find it even on the pentair site.
    Anyone has experience with the easy touch and its ability to control solar panel valves?
    TIA
    14000K gal 400sq ft w 6x8 spa, Pentair Intelliflo VS3050, Pentair cart filter, Pentair Master Temp, Pentair Intellichlor IC40, Pentair Easy Touch 8, wireless control. 3x intellibrite LED light. Pentair Kreepy Krauley Sand Shark. Solar Panel Plumbing. 2 x 24 inch arc sheer 24" spa spill way.
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Pentair Easy touch and Solar control
    I think the water temp sensor and the solar sensor are the same item. Pentair P/N 520272
