Results 1 to 7 of 7
Thread: Question on converting to cholrine from baqucil
    I have an 18 x 33 AG oval pool, it holds according to pool store 14,019 gallons of water, I just had my water tested and the readings are:
    FC: .1ppm
    Total Chlorine .8ppm
    PH: 7.6
    Hardness: 206ppm
    Alkalinity: 63ppm
    Cyanuric Acid: 0ppm
    Copper: 0ppm
    Iron: 0ppm
    Total Dissolved solids: 1100 ppm
    Phosphate: 0
    Biguanide: 0
    Water type is Well Water
    The pool dealer told us to add shock (2lbs - Cal. Hypochlorite =52%, Min. Available Cholirine 49%) to the pool so we did, now the pool water is very hazy with a greenish tent. I have been working with them since the end of april and I am ready to pull out my hair as they keep selling products with no results or unexpected results. I would like to know if you can offer any advice to get the water cleared up by Saturday June 13th as we have a Graduation Party and of course they would like to swim.
    Any advice or help would be greatly appreciated.
    Thank you
    16'x32' oval AG; 12000 gallons; Hayward sand filter; 1 HP Pump
    Mod Squad JohnT's Avatar
    SW Indiana
    9,199
    Re: Question on converting to cholrine from baqucil
    Welcome to TFP.
    Start with the Pool School article: http://www.troublefreepool.com/pool-...ine_conversion
    You really are going to want a test kit, especially if you are in a hurry. Taylor K2006 or the TF100 from TFTestkits.net are far and away the best deal.
    I would start by lowering your PH a little to between 7.2 and 7.4. Then it is time to stock up on bleach or liquid chlorine. Check around in your area and see if the pool stores carry liquid chlorine and what it costs and compare to bleach at places like WalMart and Aldis. Since your biguanide level is already zero, you won't need as much chlorine as some of the other people on here, but still you will need a fair bit.
    Read the article JohnT linked to, and read some of the other conversion stories. If you have any questions just ask. There are lots of people around here happy to answer questions.
    Jun 2008
    Carrollton, GA
    88
    How tall is your pool? I also have a 18X33 above ground pool. Mine is 54 in tall and it holds around 15,700 gallons of water. This might make a difference in how much chlorine you need to shock your pool if it is as tall as mine. Take your water back to pool store and have it tested for chlorine level, then go home and calculate on the pool calculator on this sight how much chlorine you need to add. This depends also on the strength of the chlorine. The pool calculator is pretty simple to use. I converted from bacquacil last year and got a good test kit from this site before I started and have only been back to the pool store to get socks for my skimmer and a pressure gauge. Have not regretted it and saved $$$$.
    Good luck with you conversion
    Susan
    18x33 AGP, BAQUAPURE 200 lb sandfilter, 2 1/2hp Workhorse pump (2 speed)
    Riverside, CA
    62
    I didn't have a test kit, although I wish I'd ordered mine before I started to convert. Anyway, I did use my strips that measure FC to see what it was if it was below 10 and then I used the pool calculator on this site to figure out how much bleach I needed to add each time. The pool calculator saved me! As soon as I am done with work, I will become a TFP supporter. I spent a lot on bleach, but the two pool stores were killing me. I got different advise from both stores and neither worked as well as TFP! If you can do the bleach thing 3-4 times per day it goes much quicker as I've learned. It was worth coming home for lunch yesterday and adding bleach. Today I can finally see the bottom of my pool. See my "thread" topic, whatever you call it with photos this week. I think it something like, started a conversion last sunday.
    Good luck to you,
    horsegal
    10,000 gallons Splash Pool; cartridge filter; vinyl; AG; pump Sta-Rite 1 HP
    Thank you to all for your responses, it is nice to know I am not alone. When I started with the pool place my bac level was at 85, it has taken a while to get the pool back to what I would call normal, I will use the advice and purchase a test kit as well as using the pool calculator. This website is great!
    To answer the question asked my pool is also 54 inches tall.
    Thanks again to all! I will let you all know how it goes.
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Good luck - with such a short time frame, frequent testing and bleach additions will be key here - as much as every hour or two at first...
