Hi everybody,
Just relocated my pool equipment and have a question about the wiring.
I do have a sta-rite variable pump and two heaters, one electric for maintaining the temperature and a propane heater for quick warm up. I'll operate the propane heater manually, probably.
The electric heater needs to switch on the pump before running. Before I had a simple one speed pump hooked up to a timer. Now I do have the variable speed pump.
So I bought the Intellicom Communication center. Can I hook up both heaters to that? And will I lose my internal program on the pump when I hook up the RS-485 cable to the pump?
My intention was to hook up the electric heater to terminal 3-4 and set program 1 to 1500 or 2000 rpm.
Will my normal programming still be functional? And do I need to hook up the gas heater as well or just keep that one manual, like I'm using it for a 2 or 3 hour heat up, to make it simple.
Your input is highly appreciated, thanks in advance!
Caesar
Caesar
