Hi,
I am just starting to investigate on how I could properly take care of the pool.
I have conflicting information.
It is a above ground 19000 Gallons with one skimmer 2 holes (one plugged).
Two out take lines but only one is connected. (perhaps the other one is a spare one).
Pump is 0.75 HP and sand filter is a 50 GPM.
I want to move the pump and filter as I would like to expand my deck.
There will be about 80 feet of 1 1/2 pipes and (10) elbows. Pump and filter will be below the level of the water and most likely at the level of the intake.
My Pump is dead. I need to change it. I would need to purchase a pump that take on account the new configuration.
I am wondering what is the impact of the head loss added with the new pipes and 90 elbows added. According to my calculation I am close or above 100 feet head. which seems to be very high.
What should I do?
Find a solution to reduce the head footing?
Should I upgrade to a 1 HP?
It would be great to have advices from member of this forum.
Thank you
Cheers
What should I do?
Thank you
Cheers
