Thread: First Overnight Test
    May 2009
    Mauldin, SC
    3
    Hello all,
    My FAS-DPD kit arrived yesterday and I was able to perform my first overnight test. I have not shocked the pool since opening but the water has looked good from the start. I have been using a standard DPD kit to keep my chemistry regulated up until now. I figured that I would shock it after I got the FAS kit just to be on the safe side but it looks like I don't need to. What do you all think?
    Last night 10pm (Turned off SWG)--2.4 FC 0 CC
    This morning 6am--2.2 FC 0.2 CC
    Other numbers are:
    PH 7.6
    TA 100
    CH 225
    CYA 60
    Thanks in advance for the input.
    Mike
    AGP-11,800 gal-Vinyl-Hayward S180T90 High Rate Pro Sand Filtration System-Chlorease SWG CL02
    30,419
    Re: First Overnight Test
    Hey, Mike,
    Those are great numbers and it sounds like your water reflects that. I think it's time to go swimming! Nice work.
    Your FC level is a bit low. A SWG with a CYA of 60 should have a minimum FC level of 3.
    Also, I would raise CYA up to between 70 and 80.
    Butterfly's Avatar
    South Carolina
    10,045
    Hi Mike,
    Have you seen Water Balance for SWGs in Pool School?
    You might want to do some tweaking.
    Welcome to the forum
    You're done SLAMing when:
