So I completely re-plumbed my new pool to prep for solar install tomorrow. I put in a couple bypass valves, one between the solar in/out and the other between the heater in/out. So I was curious how much pressure the heater introduced to the system and I was actually shocked. My pool is roughly 21k gallons, with a pentair sand filter and an intelliflow VS. My pool high setting is set to 3000 RPM on the pump speed. With the heater inline my pressure on top of the sand filter is 22psi. If I open the heater bypass that I just installed, my pressure drops to 18.5psi. I was kinda taken back that the heater was that restrictive. I'm sure the solar will be quite restrictive as well, I'm anxious to see that number tomorrow (qty8 helicol 4x12 panels). All plumbing is 2"
So my question is will I gain efficiency of heating the water if I open the bypass valve on the heater a bit? If so, how much should I open it?
Thanks crew!
Thanks crew!
