Hi,
New to forum. Been reading lots over a couple of days. Sorry for the long winded first question/post.
My question is how much CC is too much? I've read that its most likely due to binding with urea or other waste but I've been unable to drop the CC level. I had thought it would be eventually oxidized and filtered.
I tried MPS shock (a couple of times) and after the MPS level eventually dropped so I could measure the CC level, the level has been consistently (for over a week now) about 1ppm. I've also tried a chlorine shock (3-4x higher than the CC level, not the 10x ratio) and have been trying to keep the FC near 5-6ppm for a couple of days to see if its just a matter of time before the CC drops but I don't see that happening.
So, being late October, I'm wondering if I have to be concerned about the higher CC or just live with it until next fill (hopefully in the spring). How much CC is really too much?
As background (using a ColorQ Pro kit) I've got my pH to ~7.4/7.5, TA at ~90ppm, CH ~ 160, FC ~4.5, TC ~5.5, CYA ~65. Before anyone jumps on the ColorQ I can't easily the TF-100 in Canada although I will have one sitting at the border in a couple of weeks and I'll do a bench mark with the ColorQ.
So, I made the early mistake of listening to pool store expert blindly (I'm a EE so I really should have known better - shame on me). I added ~ 50ppm (I think, need to do the math) of borates, and a SPA enzyme (only twice, last time was 1.5 weeks ago). Is the enzyme somehow responsible for the higher CC?
I've only had the tub for a couple of weeks and after using dichlor the CYA was in the 70ish range so I quickly dumped the dichlor and grabbed some Clorox.
Now on to my second question.
Here in Ottawa, Canada I've tried 3 or 4 grocery stores and everyone carries Clorox Original but its UPC is not coming up on the Clorox site and nowhere on the label is the % Hypochlorite listed. It *appears* that its much lower than 6%. Using pool math (or actually HotTub&Pool calculator app -- great app), I almost had to double the quantity to get the expected improvement. Anyone ever hear of 3% Clorox?
I actually picked up a 10.8% jug from a pool store and the expected rise in FC was almost bang on so I'm a bit confused about the Clorox? Has the formulation changed recently, I've seen on the Clorox site there are a few other things actually in Clorox, Sodium polyacrylate, sodium carbonate, sodium hydroxide, etc. Are all of these ok or has the formulation changed? Is it just for pH balancing?
