I am looking to replace the lights I have on my pool. I have a "pool light" in the deep end, and a "spa light" in the shallow end. I have been looking at the Pentair Intellibrite 5G Color lights. My questions are about controlling them.
1. My understanding is that if you put these lights on light switches, you switch off and back on to cycle through colors and shows. I have the intellitouch system with a easy touch panel inside. Would turning the lights off and on from the panel (pressing the button) also cycle the light colors? If both lights are on the same button, would that work for both?
2. If I got the LED Light controller, could both lights be controlled with one controller? Or would I need a controller for each light?
3. If I can control both lights from one controller, then I would assume I would select the color/show I wanted from that controller, then I can use the easy touch keypad to turn the lights on and off?
TIA
TIA
