A couple of days ago, I noticed that the 20 day old water in the spa had lost a bit of it's sparkle. The FC, pH and other parameters have been OK since the refill; still, for good or bad, I decided to treat with MPS.
I should have put in 30g (6 tsps), but wasn't careful enough and ended up putting twice as much , 60g (12 tsps).
Here we are two days later and the FAS-DPD test shows FC at 17 ppm; pH 7.6.
Now the water is clear, and the other parameters as in my signature.
So my questions are:
Note: I've left the SWCG run unchanged, so the usual chlorine quantity is being generated.
Regards,
Ron
- Is the water safe to soak in?
- Is the pH reading reliable?
I have read that at FC levels 10ppm or above, the Taylor pH test is unreliable. - How can I monitor the 'true' FC level, while the MPS throws the reading off?
Regards,
Ron
