PROBLEM SOLVED!
Called the pool repair store. The person that answered knew immediately. "Change the Sand". Changed the sand washed off the laterals and the problem went away.
Not sure, but suspect that the sand had been worn down over the years to a point where it was completely blocking the laterals. The clues were that it only spurted when set on filter and that it first appeared in short bursts on initial pump startup following a backwash. This clue actually started over a year ago, but never gave me a problem other than spraying me at initial pump on time.
Might be a good clue for me to know when to change the sand. NOTE: I let the pool repair shop do the work. Probably could have done it myself, but they earned it with the diagnosis... plus it looks like a tough job to do it correctly.
Thanks for all your help.
