This is my first post here although I've been reading these forums for a while when I have questions and usually find a lot of solutions to my pool issues. So, hello all. I've had my pool for 8 years, getting ready to close and thinking about not covering the pool this year when I close. I still plan to use winterizing chemicals and drop the water level like always, just not cover. The debris from trees is minimal once the leaves have fallen, and I'm wondering if covering is worth the effort and drawbacks. The drawbacks of using the cover are (1) its a safety cover and its heavy and a hassle to get on and off and clean (2) I have a couple of dogs that want to run on top of it, leaving their muddy foot prints to wash through the mesh screen and into the pool when it rains, causing a lot of dirt build up in the bottom of the pool that I have to vacuum out manually when I open in the spring.
For reference, my winterizing process after cleaning and balancing is
(1) lower the level (2) put in winterizing chemicals (3) circulate the water about 2 days to mix the chemicals (4) drain pump and filter, and spray pump protector in pump, install freeze plugs in the skimmers. I've never blown out lines - I live in Eastern North Carolina and the winters are mild with only occasional hard freezes. It almost never snows and when it does, just a couple of short lived inches.
So I would still do all that, but just leaving the cover off would save a lot of the work. I thought I could just throw a nice light leaf net over it instead. My question is - is there anything I'm missing about an advantage to using this cover? I can't think of any, but would like to know what others think (or do) and would appreciate thoughts.
