New pool owner here - it came with my new house. It's getting colder up here in Maine, and the water temperature is below 60. Time to close up the pool, but I'd really appreciate feedback to see if I'm following the right plan. This is an above ground pool with a very simple setup. I only have one skimmer, which goes straight to a pump, which connects to the filter, which leads to a third unit (chlorinator??), and finally back into the pool. Steps I'm planning to take, in this order, are:
Additionally, I've got this third unit which is downstream of the filter.
I'm guessing this is an automatic chlorinator? What would I need to do to get this ready for winter?
Thank you!!
- Vacuum/clean pool as much as possible
- Remove skimmer basket and wall fittings/jet eyeball
- Lower water 12-18" below skimmer by siphon
- Adjust pH (7.2 - 7.6)
- Adjust alkalinity (80 - 120ppm)
- Do I need to bring up chlorine to 1-3ppm??
- Drain pump, DE filter (with a flush), and third unit (see below)
- Blow out lines with shopvac
- Should I do any maintenance/upkeep on the pump or filter??
- Clean pool if still needed
- Do I need to add algaecide??
- Leave mesh cover over the pool; remove before ice forms
Thank you!!
