Thread: Fiberglass builder in SC?
    Hey everyone! I am new to this forum. I am desperately searching for a pool builder that installs either Leisure or Trilogy pools in our area. Any leads?
    I'm new here and I need to figure out how to post my signature but for new we're just in the planning phase! Thanks in advance!
    In the process of building a pool. Planning for:
    17 K gallons, 37 X 14 fiberglass, 1.5 HP pentair pump, cartridge, SWG
    Re: Fiberglass builder in SC?
    Found a good pool builder in sc that will install in my area. Thanks! http://www.atlantispoolsusa.com/ I hope to put a pool in this fall and will post pics once I do!
    Butterfly's Avatar
    South Carolina
    10,045
    So glad you found a builder!
    Yes, please keep up posted thru your build including those wonderful pix
    You're done SLAMing when:
    I will! Thanks!
    frustratedpoolmom's Avatar
    SWSuburban Chicago, IL
    11,969
    Signature:
    Go to User Control Panel, then Profile, then Edit Signature.
    Good luck with your build!
    Thanks! Got the signature up and the avatar!
