Results 1 to 8 of 8
Thread: Proper pool shed foundation
    Aug 2014
    NJ
    426
    I am plannig to purchase a shed for my backyard (to store all pool related stuff like chairs, floats, etc). It will be about 10 x 16 or 12 x 16 or maybe bigger if once we get there we decide on a larger one. My question is what type of base should I use? Some places suggest gravel (or rocks). I would have thought concerete but that seems to be discouraged.
    Any thoughts.
    1200 Sq Ft 41,000 Gal. Gunite, JANDY SVRS VS pump, JANDY JXI 400,000 BTU, Polaris 280 w/ 3/4 BP, Rockwall and Grotto (w/6 jets and blower), 2 JANDY Lam Jets, 2 LED Bubblers, 5 Ledlights, AQUALINK P16 RS, 90% Quartz, SWF 185 GMP BP, SWF 125 BP, Levelor K1100 Autofill, AP Digital SWG, 2 skim and 5 returns, and mostly 3 inch piping
    Jul 2016
    McKinney
    5
    Re: Proper pool shed foundation
    call me old fashioned, but concrete slab is the most stable. Not difficult to pour yourself, just prep the area first and then re-bar and forms before the pour.
    Apr 2013
    Sacramento, CA
    2,769
    My shed has a concrete floor.
    Mar 2015
    Sugar Land , TX
    391
    I used 12 x 12 cement stepping stones to make my square pad
    8500 gallon IG Pebble Sheen with Spa. 3hp Pentair VS Intelliflo ( pool ), 3/4 hp WhisperFlo ( water feature ),Pentair Racer, 400K Pentair heater, Pentair 500sqft Cartridge filter, EasyTouch 8, Stenner 45mp2 15gallon wired to ET8
    Isaac-1's Avatar
    SW Louisiana
    6,711
    The correct answer will probably depend on your local soil conditions, issues with freeze and ground heave, etc.
    Aug 2014
    NJ
    426
    Thanks everyone
    bmoreswim's Avatar
    Jul 2012
    Central MD
    3,443
    Stone is great for prebuilt sheds in freezing climates. Even the stone and drop the shed on it. Easy peasy and super solid. Wood sheds that size are heavy and don't move and bit.
    Mine is on pavers dug into soil. Harder to do the prep getting them all level though.
    18'x38' Rectangle (3'-8 1/2' deep w/ diving board) - 27K gal. w/ gray plaster
    Hayward equipment (cartridge filter, 2-speed pump, SWCG, automation) View Our Build
    Coverstar automatic pool cover | StoneMakers concrete retaining wall and decking | Merlin SmartMesh winter safety cover
    Spring 2013 Build | Dolphin Active 20 robot cleaner | Support TFP!
    Aug 2014
    NJ
    426
    Quote Originally Posted by bmoreswim View Post
    Thanks for the confirmation. That was the way we are planning to go.
