Thread: Best place to buy a Hayward Ecostar
    Dec 2015
    Krugerville, TX
    23
    I'm in need on a new pump. I've decided on the Hayward sp3400vsp. I don't think I need the vspvr since I have a dual bottom drain system which should prevent any suction safety issues.
    Now I'm wanting to know the best place to buy one. A quick google search has swimmingpoolsupplyusa.com as the cheapest place. I curious where other have purchased pumps. Thanks.
    20yr old,14k,IG,Plaster,Hayward Pro-Grid 60sqft, Hayward DE Separation tank, Hayward Multi-port Valve, Whisper-flo single speed 1.5hp pump,Hayward XL concrete pool suction vacuum, Polaris P340 (Leslies Pool model), Still working to get a test kit, Leslies Power Powder and Leslies 3" Tabs.
    Divin Dave's Avatar
    Oct 2013
    Longview, Texas
    4,940
    Re: Best place to buy a Hayward Ecostar
    Hi,
    here are a couple for you.
    Poolsupplyworld dot com
    Inyopools dot com
    sunplay dot com
    Good service from these guys from personal experience.
    Divin Dave,
