Results 1 to 9 of 9
Thread: Extra 3/4" pipe
    Nov 2014
    East norriton pa
    4
    Extra 3/4" pipe
    Hey guys, I have an 35,000gal concrete inground pool and I have an extra 3/4" pipe that I'm trying to figure out. It stubs up at the equipment pad the other end comes out in the pool wall about 1/2 way and 1/2 way up the wall. Would this be for a automatic cleaner? There is no booster pump and the pipe is just stubbed up and taped off. I really can't think of what this else this could be. Any input is much appreciated.
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    30,608
    Re: Extra 3/4" pipe
    A picture of the pipe in the pool and at the pad would be helpful. What does your PB say? Does you contract say anything about about a cleaner? Sorry for more questions than answers but.........
    Kim
    Isaac-1's Avatar
    SW Louisiana
    6,711
    Re: Extra 3/4" pipe
    2 things come to mind, a pressure side cleaner, or a conduit for the pool light power cable.
    Dec 2014
    Houston, Texas
    134
    Re: Extra 3/4" pipe
    Is the line at the pool above the water line or below? Could be for a fill line, usually pressure side cleaners are run with 1.5" PVC.
    Sep 2016
    Escondido/CA
    638
    Re: Extra 3/4" pipe
    I have this very same thing. Your description might be exactly describe mine. I'm pretty certain it was installed for a pressure side cleaner. My neighbor has one and uses it for a pressure cleaner.
    Jon -- 28kgal, IG, AquaBright, Attached Spa, ~1990, Quad DE 80, Easytouch8, IntelliFloVS-3050, Intellichlor60, IntelliPh, Dolphin DX6, City Water, K-2006/TF-100, SpeedStir, SampleSizer, San Diego, CA
    Nov 2014
    East norriton pa
    4
    Re: Extra 3/4" pipe
    Sorry the pipe is 1" not 3/4" dunno why I typed 3/4". The pipe is about 18" under the water line and comes out a little less then the halfway point of the overall length of the pool. The other end stubs up at equipment pad. The pool was built in 1977 so no asking the builder, it's definitely not a conduit for lighting because I already have lighting and it's plumbing pvc not electrical conduit. I can't take any pics because I'm all buttoned up for the winter. I actually have the blueprints from when it was built that came with my house and they just say "extra pipe stubbed at pad". So I guess its provisions for a pressure side cleaner. Would I be able to run a booster pump and cleaner on a 1" pipe? Again thanks for all the help!
    Nov 2014
    East norriton pa
    4
    Re: Extra 3/4" pipe
    So after looking at the blueprints again I actually found something in the notes that looks like it says "stub plumb for ps". It figures the only part of the blueprints that have a smudge on them is right there but that's my luck! So I guess I kinda answered my own question🤔.Also after some googling I found that Polaris says a 1" will work. What would be the downside(if any) of using a booster pump and p.s vac on 1" pipe! Thanks
    Jul 2012
    Tallahassee, FL
    30,608
    Re: Extra 3/4" pipe
    LOL of course a smudge right THERE! I bet you are correct.........it is/was for a future PS cleaner. I don't know which one would be better, sorry.
    Kim
    Mod Squad pooldv's Avatar
    DFW, TX
    24,509
    Re: Extra 3/4" pipe
    Yes, my booster pump is plumbed with 1" pipe. But, it would be much better to get a robot like this one, First Robotic Cleaner, Doheny's Discovery
