Results 1 to 9 of 9
Thread: New pool installation--starting from scratch
    Aug 2016
    Warminster, PA
    21
    Hi All,
    Finally broke ground today on our new pool installation--just a couple quick questions about the TFPC method when starting from scratch. I have a TF-100 on order.
    Pool is an IG Fiberglass Viking Coronado, 13000 gallons, Pentair Intelliflo VS pump, Pentair Cartridge filter (320), Intellichlor SWG, and Pentair electric heat pump (125 btu). I'm located in the Philadelphia suburbs.
    I have been lurking here for a couple months, reading about water chemistry and the basics of TFPC. Once the pool is filled, what order do I begin balancing water chemistry? Builder will be adding the salt.
    From what I've read here:
    1. Add cyanuric acid to 70-80 ppm, as well as bleach initially to keep FC levels adequate. Ground temps (and I'm assuming water temps) are averaging around 65F right now.
    2. Adjust TA to 60-80 ppm.
    3. Adjust pH to 7.2-7.8.
    4. Adjust Calcium hardness to 220-320 ppm.
    Does this sound about right? Am I missing anything obvious right now?
    Any help would be much appreciated. First time pool owner here, and I'd like to start this off on the right foot.
    Casey's Avatar
    SW PA
    10,163
    Re: New pool installation--starting from scratch
    Check your pH, TA and calcium first and adjust as needed. Good luck with your new pool!
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    27,725
    You can check your fill water to know what you are dealing with from the get go.
    We would LOVE to see your build as it happens!
    Kim
    Aug 2016
    Warminster, PA
    21
    Well, here is the big hole.
    Attachment 55120
    Jul 2015
    Landale, PA
    101
    Good luck with the new pool, very exciting. Also as a new pool owner. this site has been invaluable.
    To be built Spring 2016. 750 sq foot gunite free form. Raised spa with spillover and dedicated pump, 16 foot fiberglass slide built into hill with bolder steps, approx 1,000 sq foot stamped concrete deck, Pentair VS+SVRS pump, Sta-Rite 400,000 btu gas heater, Sta-Rite System 3 cartridge filter, Pentair Intellichlor IC60 SWG, Pentair Intellichem, Pentair Easytouch, Rapids 4WD pool cleaner, 2 LED Intellibrite lights.
    Aug 2016
    Warminster, PA
    21
    making a mess (for now) out of my back yard!
    Viking Coronado IG Fiberglass 13k gallons, Pentair Intelliflo VS Pump, Pentair Cartridge Filter (320 sqft), Pentair Electric Heat Pump (125k btu), Pentair Intellichlor IC20 SWG. TF-100 Test Kit. Located in SouthEastern PA.
    Jul 2012
    Tallahassee, FL
    27,725
    Love it so far! Was it fun to watch the crane do it's thing??
    Since your build will go fast have you thought about a test kit yet? Is your PB providing one? If so let us know which one so we can help you fill in any holes it might have.
    Kim
    Aug 2016
    Warminster, PA
    21
    yes, really interesting to watch these guys with the excavator and maneuvering the pool with it. TF-100 shipped today--i guess i'll check my tap water when it arrives to get a baseline for my chemical needs (i am filling from the hose bibs).
    Jul 2012
    Tallahassee, FL
    27,725
    You are right on track then! Yes, do check the fill water. I wrote my down and have it at the front of the test log.
    Kim
