Thread: Clean algae in drained seasonal pool?
    LaughsBrightly's Avatar
    Oct 2016
    Toledo, OH
    1
    Question Clean algae in drained seasonal pool?
    Hi all! I want to start off my first post by thanking everyone who posts here. When we got this seasonal above-ground pool for summer I found great help here. Using nothing but stuff from Wal-Mart (and PoolMath!) I was able to keep the pool crystal clear all season without breaking the bank.
    Unfortunately, we have been busy the last 3-4 weeks and not adding chemicals. We have drained the pool and now have algae all over the bottom. Tried vacuuming and the algae just goes out the little bag thingy.
    Suggestions on how to clean it for packing? I was thinking some of the Wal-Mart liquid chlorine (10% I think) mixed with water and some type of deck brush? Then rinse as best as we can and pump it all out?
    Thanks!
    2,708g Bestway Steel Pro 12' x 48" Frame Pool Set (seasonal) | PVC and polyester 3-ply wall | Bestway 530g filter pump | 5-way test kit |
    Dec 2015
    Hawera, Taranaki, New Zealand
    443
    Re: Clean algae in drained seasonal pool?
    I thinks thats what I would do with a mix of 4:1 water bleach, spray, scrub with a soft broom/brush and rinse once the pool was empty. Make sure to dry the liner off before you pack it away
    6000 gal, AG vinyl, Intex ultra frame 16ft, 1200 Gallon Sand Filter, DIY Solar, Clear Choice Labs Testing Kit
    Mod Squad kimkats's Avatar
    Jul 2012
    Tallahassee, FL
    27,725
    Quote Originally Posted by Caco View Post
    Solid plan there ^^^
    Kim
