Thread: Do you think this is necessary?
    Apr 2016
    Denver CO
    70
    What do you think about these hot tub guidelines?
    Do you do this?
    Recommended Monthly
    Microbiological tests for indicator organisms.
    Clean input air filter when fitted.
    Inspect accessible pipework and jets for presence of biofilm;
    clean as necessary.
    Check residual current circuit breaker /earth leakage trip is operating correctly.
    Check all automatic systems are operating correctly eg safety cut-outs, automatic timers etc.
    Disinfectant/pH controller - clean electrode and check calibration (see manufacturer's instructions).
    Quarterly
    Where possible clean and disinfect air lines.
    Legionella tested by lab
    Btw I read where someone said this is a chlorine forum? Really?
    Mod Squad pooldv's Avatar
    DFW, TX
    24,514
    Re: Do you think this is necessary?
    Yes, we are big fans of chlorine. There is no better way of maintain a pool or hot tub.
    The process is how I have maintained my hot tub for 4 years or so. I drain it a couple of times a year. I use a TF-100 from TFTestkits.net to test my water. Lots of folks recommend using Ahh-some to flush out the tub when draining but I haven't done it yet.
    How do I use Chlorine in my Spa (or pool)?
    needsajet's Avatar
    Jan 2016
    Sydney, NSW, Australia
    4,285
    We like our pools/spas to always be available for use (that is... sparkly clean, safe and comfortable for people) and never turn green the day before a party.
    I can't comment on the whole list you posted, except that the sanitizer sensor might need to be calibrated more often than monthly. I haven't heard of any TFPC users needing to test for pathogens. What sanitizing system are you using?
    12k IG salt; glass beads in plaster; K-2006C, K-1766, CCL, and Aussie 4in1 (HTH); Pentair Eco800 1.2HP VS; Zodiac SWC 1.3 lb/day (25 g/hr); 25" filter recycled glass; OKU solar panels; 1/2 HP solar pump; Rebel (Warrior) pool cleaner; FlowViz; prior pool AG 10k | Read Before Posting to get the best possible advice | ... and this helped me a lot!: TFPC for Beginners
    Apr 2016
    Denver CO
    70
    Bromine
    JoyfulNoise's Avatar
    May 2015
    13,258
    Unless your hot tub is open to the public and used by every Tom, Richard & Harry (sorry, D-word is prohibited), your likelihood of developing Legionnaires Disease isn't very likely. Testing for it is a waste.
    Also, just use a biofilm cleaner once or twice a year (we recommend Ahh-Some) and you'll never have to worry about biofilms (or go looking for them).
    Matt
