Thread: Cleaner for Summer Waves pool
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    We have an 18 x 48 Summer Waves AGP. It has the in-wall skimmer and 1 return. Our manual cleaner is not cutting it right now with the dust storm we have been having. We have cleaned the pool 5 times since yesterday and it is still not clean. Our pool is never going to be clean enough to close when it gets cold enough the way things are going.
    You know why Oklahoma is so windy? Because Kansas sucks and Texas blows.
    VinDeeLoo
    7600 gallons ~ AG ~ Summer Waves Cartridge C Filter ~ using pump that came with our Summer Waves 18 x 48 pool ~ Taylor K-2006 (SpeedStir & Sample Sizer) ~ no well water or water restrictions
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Re: Cleaner for Summer Waves pool
    I just got a Hayward Aqua Bug and LOVE it, but I think the problem you are going to have is your filter and pump system flow rate.
    I ran Wanda the Whale on my old Intex 2150GPM system and it ran great with the skimmer off, cleaned up a very dirty 18' pool in about an hour. When I hooked up the new Hayward system I was able to run Wanda and my skimmer together.
    Do you know the flow rate of your system?
    EDIT:
    I just found this Walmart ad, is this your pool?
    https://www.walmart.com/ip/Summer-Wa...y-Set/49220360
    It lists a "1500 gallon cartridge filter pump", but that could be the technical spec of the pump, not the system flow rate.
    Dom - TFP Guide
    Intex 18' X 48" Ultra Frame AGP 6700 gallons | Two Intex CS8110 SWG's | Hayward Pro Series 21" Sandfilter | Hayward 1.5HP Power Flo Matrix pump | Hayward Thru-wall Skimmer | Wanda the Whale | 72 sq ft of Sungrabber Solar Panels with Hayward GLC-2P-A | Taylor K2006 Test Kit, Sample Sizer & Speed Stir | Click Here To Become a TFP Supporter!
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Yes. That is what we have. Not sure Wanda would work because we don't have that type of skimmer.
    VinDeeLoo
    domct203's Avatar
    Jun 2015
    CT
    3,597
    Is that the skimmer that has the pump & filter built into it? If so, I'm not sure how you would hook up any automatic vac.
    If you had another pump & filter you could just hookup that to an auto vac and throw the hoses over the pool wall (the Aqua Bug manual mentions that as an option in Step# 7 of the manual https://www.doheny.com/Pdfs/4947.pdf ).
    They also make pressure side sweepers that hook up to the return jet. They pretty much just stir up the bottom so more debris makes it into your filter.
    Here's the Intex version:
    https://www.amazon.com/Intex-28001E-.../dp/B00GSPHSRO
    Good luck.
    Dom - TFP Guide
    kellyfair's Avatar
    Jun 2016
    Tampa, FL
    1,286
    The intex version is awesome- it does stir up the bottom, but it also picks stuff up. I'm always amazed at what it manages to suck up.
    16' by 4' Intex Ultra Frame AGP
    Intex 120V Krystal Clear Sand Filter Pump & Saltwater System CG-28679 with E.C.O.
    Hayward Through Wall Skimmer, Intex Auto Cleaner - works great!
    TF100 Kit and Speedstir
    Get the Pool School ebook, free on Google Play!
    VinDeeLoo's Avatar
    Jun 2016
    Tonkawa/Oklahoma
    204
    Quote Originally Posted by kellyfair View Post
    Do you have a Summer Waves? Wondering if hoses will fit.
    VinDeeLoo
