Thread: No FC loss over days
    Jun 2014
    Marietta, GA
    95
    Now that is is fall, and the temps are cooling down a bit, I would guess that FC loss would be lower than in the summer, but is it normal to lose very little if any at all? My water is clear, and all other readings are normal, except maybe my calcium which is 120, but I have a vinyl lined pool. I tested the FC 3 days ago, and it was 6.5 (13 drops), and I just tested again, and it was 6. That is only a .5 drop in over 3 days, is this normal?
    27k gal, IG vinyl, Pentair Triton II Sand Filter, 1 HP Hayward Super Pump, Liner 3 yrs old, Intermatic PF1103T Timer w/ Freeze Protection, K-2006.
    Mod Squad Jimrahbe's Avatar
    Jul 2014
    Bedford, TX
    5,608
    Re: No FC loss over days
    You are correct that FC loss slows down as the winter approaches. A .5 drop over three days does seem a little low to me, but it really depends on how much sunlight your pool has been getting and the water temperature.
    Since FC can't increase on its own, and assuming no testing errors, I see no reason to do anything but keep testing every few days.
    GaryT58's Avatar
    Jul 2016
    Monroe, GA
    570
    That seems very low. Can measure your water temp? And as said, sunlight is a major factor. I am in same basic area as you, but my temp is about 72-74 because I have been keeping covered, and I get direct sun now from about 8:30-4:00. So I am still running my SWG, although at lower %age.
    38'x16' Fiberglass pool - 3.5' - 8' deep - 19,000 gallons. AutoPilot Total Control SWG (RC-52 cell), Pentair SuperFlo VS, Pentair SD70 Sand Filter, Coverstar Automatic Cover, 10' board, PAL Treo lighting, Polaris 9550 Sport robot, Lamotte ColorQ Pro 7 test kit.
    Catanzaro's Avatar
    Jul 2014
    Monmouth County, New Jersey
    2,195
    If you have not added anything to your pool (no chlorine in any form), it has not been used and nothing has fallen in the pool (leaves, etc.), then .5 in 3 days with no cover on is probably due to slight testing error. Was the testing exactly 3 days later? The good news is that, here at TFP, we all now that all the extra "magic potions" that the pool stores sell are really not needed. Take Care!
    Numbers ok but water has a hint of cloudiness - Page 6
    Please look at post # 114 (Chem Geek) Excellent post on the margin of error when it comes to testing. The whole thread is very interesting.
    14,700 gallons IG Pool Vinyl Liner - Octal Circulation System
    Hayward Pro-Series 350 LB. Sand Filter Model # S270T - 2" Plumping
    Hayward CL2002 Chlorinator - Hayward Super Pump 2 HP Model # k48m2n111
    Hayward AQR9 SWG 25K Salt Cell & TF-100 Test Kit + Speed Stir
    Gulfstream HE125RA - 117K BTU Heat Pump - Date of Build is 11-2013
