Closed above ground pool, did I do okay?
Gardenmom
75
Syracuse, NY
We just closed our 15x30 ag pool. We have a solid cover, vacuumed all debris, drained the water below the skimmer and used a skimmer plate and put a plug in the filter outlet. In years past, we would use the packets of shock in the pool prior to closing, but with our CYA so high, we just added chlorine. Our numbers are:
FC/ TC- 18.5
CC-0
pH-7.9
TA-150
CH-110
CYA- 100, down from 140 with partial drain.
We just stopped using the pucks in early August, so first time not using the packets of shock. Are our numbers okay for the winter? We live in Central New York, where winters can be snowy and cold.
Thanks!
Has all the water been removed from the return line and your DE filter, pump, etc.? If so, your CYA will come down naturally next year. If you added PolyQuat 60, it would be added protection. Although, with high FC levels, chances are that you will be perfectly fine. Please open the pool up early next year, at least one month earlier than the holiday.
